12v Battery drain and DOME fuse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LBH, Aug 13, 2019.
  1. *Goldfinger*
    *Goldfinger* Junior Member
    81
    Sheffield, England
    Hi Patrick,
    Thanks for this great info. I too have a 0.4A draw on the 'Dome' circuit. I can't be bothered with trouble and expense to replace the Combination Meter but if it does turn out to be the culprit do you think it would resolve the problem if I traced the power wire to the Combination Meter and spliced a simple on off switch into it, which I could mount on my dash, so I could turn the power off before leaving the vehicle.
    Thanks
    David
  2. Patrick Wong
    18,210
    6,522
    I suggest you look for a stuck relay first.
    *Goldfinger* likes this.
  3. *Goldfinger*
    81
    Sheffield, England
    Thanks will do :)
  4. *Goldfinger*
    81
    Sheffield, England
    Update - I didn't have a parasitic draw after all. It turns out just checking the circuit when everything was asleep woke up the circuit and created a the draw.
    Thanks everyone for your invaluable help and advice.
