12V Battery Fluctuations
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Jul 31, 2013.
  1. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi srivenkat,
    There will always be some voltage differences depending on where you take the measurements. The farther away from the Aux. Battery, the more the voltage drop due to loading. You can use your digital multimeter and verify it yourself.
    Vincent
  2. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I did some testing this evening. The voltage at the jump point is identical to the voltage I saw at the cable that plugs into SGII; I used a Digital Multimeter and tested the voltage using the 2 extreme ends of the RJ-45 cable end. What this tells me is that the SGII itself is the one showing the lower voltage (~ 0.23v) than it is receiving. Perhaps there's a diode of sort within SGII that does some forward limiting while not allowing current to go from SGII to the OBDII port?
    I suspect in the testing you did with the 9V battery, the SGII was showing you about 0.23v less than what the 9V was actually supplying...
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    More likely just a simple gain (linearity) error. A 0.23 volt difference is less than 2%.
