12V battery going dead
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, May 5, 2024.
Thread Status:
Not open for further replies.
  1. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    True, but....
    I'm not sure what you're looking at, but it's there in the EU manuals. Maybe not present in the US version? We're dealing with a Canadian here (maybe that explains some things). o_O
    28850-K0010 SENSOR ASSY, BATTERY STATE
    (It's not "molded into the battery" though, so yet another incorrect conclusion being drawn about it being a special magic battery.)
    Gokhan likes this.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Steady voltage drop, rather.
  3. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I can't tell much from the diagram, but is seems fairly integral to the battery. It can't be any sort of voltage sensor, because that could attach to the main leads. My guess would be internal sensors for temperature and/or cell balancing.
  4. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    The diagram and photo are pretty clear. It's obviously clamped onto the terminal, and not part of the battery.
    The 3-pin lead is bringing in 2 12V lines from the fuse box, and sending an indicator out. It's comparing terminal voltage to the rest of the 12V system.
    Somehow that doesn't surprise me. You're really good at figuring stuff out.
  5. Hammersmith
    Hammersmith Senior Member
    2,483
    2,542
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Exactly. That connector/sensor is part of the negative battery terminal. It comes off when you pull the terminal off. It's not a separate sensor within the battery itself.
    (I know you already know this. I'm mostly speaking to any silent crowd that are watching this trainwreck of a thread. I'm just trying to make sure nobody else gets the mistaken idea that you can't easily replace the 12V battery in a Prius Prime. I've seen misinformation like this take on a life of its own on this forum more than once. Someone says something incorrect in a thread and is corrected about it, but a completely different new poster reads it and repeats it a couple months later.)
  6. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Here's a product page from Bosch explaining what a battery sensor is:
    Electronic battery sensor
    Basically the same idea as this one.
    otatrant likes this.
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It's not attached to any battery terminal on my car. It goes through molded connector which is part of the top.
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,087
    6,950
    Texas Hill Country
    What you want to do is a series amp monitor while shutdown. This is a definitive test and allows you to track down the parasitic draw which has to be large if it kills the battery in two hours. A $5 Harbor Freight meter is good enough.
    This technique with the negative jumper removed in step 4 reduces wait time for the computers to reach their powered down sleep states.
    In your case I would start with the 10 amp scale.
    Typically most cars have a 10-30 ma parasitic draw when shutdown and not charging. Under 50 ma is usually considered good enough to last 3 or 4 weeks with a good 12v battery. If you have a low draw it has to be the battery.
    Otherwise Toyota should find and eliminate the excessive parasitic draw. Any local mechanic can do this if you would prefer not to do it. It gives evidence one way or the other.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Call me lazy, but I used a DC clamp ammeter. I hate going through the setup each time I unhook the battery.
  10. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    You do know the metal bits are conductive, right? If it's not attached to the battery terminal, how do you think the ground lead attached to the sensor is attached to the battery?
  11. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It's definitely molded through the top of the battery, and not connected in any way to a terminal.
  12. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Apropos of nothing, always loved this sketch.
  13. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Lovely forum you have here. "You're wrong 'cause you're wrong," and "You're a troll because you're a troll," it seems.
  14. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Actually, maybe if you've got a special battery with something molded into it, rather than the standard battery with the standard Prius battery state sensor as shown in the diagram (which matches your photo), maybe that's the problem?
    Your battery sensor is missing!!!! :eek:
    And you've plugged the connector for the battery sensor into your special battery temperature monitoring port!
    No wonder it's confused.
  15. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    All I know is that I didn't want to replace the original battery with a regular battery without that connector. Instant warranty voider.
    Would you have done differently?
    And what would I gain by it anyhow? The parasitic drain would still drain a new battery.
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    My best theory at present is that the over-the air radio is not making good contact in my rural area, and may be consuming a lot of power trying to connect. I connected my home wi-fi to the car. Still waiting to see what happens.
  17. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Oh, for completeness, I should have posted the circuit for the sensor earlier along with the parts diagram. Here it is.
    (The direct electrical connection of the sensor to the battery terminal isn't shown as part of the car's circuit diagram...)
    #77 KMO, May 7, 2024
  18. Hammersmith
    2,483
    2,542
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    What you don't understand is that the part you think is part of the battery is actually part of the terminal.
    Don't believe me? Do this simple little test.
    Here's a pic I took a while back of the negative side of my battery:
    Does that look familiar?
    Now go to your battery and take off the top nut; the one right under the big label.
    Now pull up on that whole section with the plug.
    See how the section with the plug is part of the terminal and not part of the battery?
    Seriously. Try it and report back.
    #78 Hammersmith, May 7, 2024
    Gokhan likes this.
  19. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Listened to people, taken in information and tried to figure out how things work. Rather than forming misconceptions on the basis of no evidence, or even contrary to evidence, and continue to insist on those misconceptions when presented with evidence.
    If when presented with evidence contrary to your misconceptions all you take from it is "you're wrong 'cause you're wrong", you're wasting your own time as well as everybody else's.
    You can look stuff up for yourself in manuals and parts catalogues, like I just did to check the battery sensor situation.
    That does sound potentially plausible. Personally I'd just disable the DCM - I believe you can do that by calling the operator from it in the US. Maybe the same in Canada. They send a command to shut it down remotely. (And then it needs a dealer/scantool to reactivate). But I don't use/want any over-the-air functions.
    Gokhan likes this.
  20. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    OK, the battery sensor you circled, found in both Gen 4 and Gen 5, is a separate component and not part of the battery. It will come off when you remove the negative terminal.
Thread Status:
