12v battery health observation
Discussion in 'Gen 4 Prius Technical Discussion' started by Elt31987, Apr 13, 2020.
  1. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Not talking AGM because AGM isn't the OEM on Prius. Flooded lead acid is.
    kithmo and alanclarkeau like this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Only very recently, IIRC.
    For the first 10 years or so the battery was "in cabin" and IS an AGM.
  3. Mendel Leisk
    42,389
    I was idly wondering how you'd bounce back on that one, lol.
    bisco, Tyfly and davecook89t like this.
  4. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    This is the 4th Gen section of the forums though ...
    alanclarkeau and Tyfly like this.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    So do ALL 4th Gen models have the old style wet cell batteries as OEM ?
    Regardless, when the original is changed out an AGM probably still is a better choice.
  6. Fester
    Fester Active Member
    201
    198
    Ohio
    As long as my Aux Battery "Health" is concerned, if my "nominal" readings of current, voltage, with consideration of ambient temp. via the ScanGauge, deviate significantly from what I consider normal (and yes I watch, just out of "Techie" habit) it will be time to take a closer look. If after a couple of years more, which places the battery over 4 years of age, statistically I'd replace the battery after satisfying myself that the Charge system is operating normally. If an academic exercise is required, there is of course the option of direct connecting a (Calibrated and NIST Traceable) Datalogger directly to the battery and reading out to the ninth decimal place voltage, current and temperature. However given that I passed the age well noted in a certain Beatles Song, I am able to place this in its proper perspective, given the current state of the planet...:rolleyes:
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    K.I.S.S.
    (y)
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    See post #2 in this thread. The professor will explain a lot.
    tomcornell and alanclarkeau like this.
  9. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    So i took it for a long enough drive, turned the car off, popped the hood and came back 9 hours later without the key in pocket and reran the test. So looks like it probably only charges up to about 66%. So i guess ill just keep my handheld jumper packet in the glovebox for when it decides its time to go
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    I would be shopping for a new battery NOW........because I don't like unexpected "adventures".
    Even if your car did come with a conventional wet cell battery from the factory, an AGM replacement would still be a better choice. Might last twice as long.
  11. Elt31987
    205
    155
    Derry, NH
    I dont think anyone has found an H4 AGM battery. There seem to be around 4-5 Wet H4 batteries with the Champion at Pepboys being the cheapest with the longest warranty. 99.74 3 year replacement
  12. Mendel Leisk
    42,389
    I'm really reluctant to cross the infamous Sam Spade 2, but c'mon...
    Raytheeagle, bisco and alanclarkeau like this.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    TOYOTA's specification isn't for an AGM.
  14. Elt31987
    205
    155
    Derry, NH
    I'd be curious what another Gen 4 owners battery shows for voltage after about 9 hours. Im wondering if the car doesn't fully charge the battery to extend its life. I could also test this by using my
    BLACK+DECKER BM3B Fully Automatic 6V/12V Battery Charger/Maintainer
    to see if it will fully charge it. Then come back 9 hours later and rerun the test. Im assuming its safe to connect this directly to the positive and a ground point on the vehicle?
  15. bisco
    52,927
    you can connect it to + and - then turn on the charger
    #35 bisco, Apr 20, 2020
  16. Elt31987
    205
    155
    Derry, NH
    Alright, i know newer vehicles have sensors on the cables and everything else possible so didn't know if it was no longer suggested to connected straight to the battery with the car terminals still connected.
  17. bisco
    52,927
    12.4v isn't horrible, but it's more important to know what it drops to as load is applied.
    personally, i'd hang on to it, and keep the jump pack at the ready
  18. bisco
    52,927
    i would also be curious to know what others are seeing. i'd be surprised if a healthybattery wasn't held around 12.6 or more.
  19. Salamander_King
    Salamander_King Senior Member
    11,026
    8,988
    New England
    Just a word of caution. Don't rely on a single battery tester reading for accurate measurement of the battery voltage. Yesterday, I took measurements of my PRIME's 12v battery with three devices.
    Craftsman model 82141 digital multimeter: 12.41v
    Quicklynks Battery Monitor II: 12.56v
    Ancel BA101 battery tester: 12.63v
    The difference is as much as +/- 0.22v among those three devices. I don't know which one is the most accurate.
  20. Mendel Leisk
    42,389
    Geez, you're armed to the teeth"! (y)
