12V battery how long does it last?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Apr 19, 2010.
  1. 68charger440
    68charger440 Junior Member
    Denver
    I
    I know it is an old thread, but it is worth while to see how long they can last. My 2009 is still running the original 12v. 8 years and it shows no signs of failure. My car has been indestructible except for a hailstorm that left some dings in it. I just can't get rid of a car that has never given me a bit of trouble. I bought a new yellow top last fall thinking it couldn't possibly make it through another winter. Here it is a year later and the yellowtop is still sitting on the shelf with the battery tender keeping it up.
    Raytheeagle likes this.
  2. 68charger440
    Denver
    I
    Well just to finish up on my test of how long a 12v battery can last I pushed my original in my 2009 prius until it finally gave up the ghost. I knew it was weak for the last 6 months or so, but I wanted to see how long I could go. I kept one of those jump starter battery packs in the car once it started getting weaker. I had to jump it twice in the past week so I figured that was pushed as far as I could.
    Not bad getting 10 years and 175k out of the original Toyota 12v battery. I never got that many years in any other car in my life.
    chinarut, bisco and ITBland like this.
  3. George W
    George W Senior Member
    939
    520
    San Antonio
    Interesting. I just replaced my dying 12V with a Yellow Top. On a cold measurement, it reads 12.73 V direct. A cold measurement In Diagnostic mode, 12.1 V. Not sure why. According to the AGM battery tables I have seen, the Yellow Top is at 90-100% state of charge. Whether the Diagnostic mode is working correctly, I can not say. Even at the front Battery terminal under the hood, the Yellow Top only drops 1/10 of a volt with all that wiring inbetween.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    12.73V = no load; a meaning less measurement.
    12.1V = some load via diagnostic mode.
    If a meaningful load was applied, this battery was likley in 10-11V range.
    Read Post #5 & #8 to learn how to apply a meaningful load to assess the 12V battery health. Is my inverter coolant pump slowly failing? | PriusChat
  5. George W
    939
    520
    San Antonio
    Does anyone know what 'load' is being applied during Diagnostic?
  6. bisco
    52,853
    that would be useful info. i don't recall others reporting that big a drop. try it cold and turn the headlights on to see what happens.
    George W likes this.
  7. Mendel Leisk
    42,345
    By that you mean hooked up a multimeter, say first thing in in the morning? That's a good reading.
    Not sure that it matters, or is relevant. Look into the new digital load testers. I use a Solar BA5, was about $60~70 IIRC. It applies some sort of electronic "load". Before doing the test you hook it up (the 12 volt battery powers it), enter the type of battery it is, the specified Cold Cranking Amps (or Cranking Amps, or one or two other value can be entered), then push the button, and it determines the actual CCA, AND gives a verdict.
    I have the Optima Yellow Top battery also, put in in September 3 years back now. So far it's been fine. When brand new it read around 12.75 volts at-rest. Now it's about 12.6.
    I'm pretty nuts about keeping it charged, doubly so since our driving is infrequent; the car often sits idle for a day or two. During those times I hook up a CTEK 4.3 charger, just leave it on for the duration of the down time.
    Next time around, say around the 5 year mark for this battery, I might swap it for a convention-shaped AGM. Canadian Tire has one on offer, their housebrand, which is something rebranded. Believe it's physically identical to the OEM battery, and the specs are not bad.
    #27 Mendel Leisk, Sep 7, 2018
  8. George W
    939
    520
    San Antonio
    I bought that same CTEK smart charger for my 12V battery. It brought up the Yellow Top to full capacity. Taking the advice of other members, I only check the 12 V cold. The only issue I noticed with the Yellow Top is that the carry-strap wants to get in the way of the positive terminal, so I tied it back out of the way. I didn't want to cut it off since I'll have to lift it out some day. I'm no spring chicken anymore.
  9. Mendel Leisk
    42,345
    You can sneak the carrying strap off the battery, at least you can with the 3rd gen spec Yellow Top. You just kinda push it down and twist, if I recall correctly. Then shove it in the space between the battery and the car body, so it doesn't get lost.
    I use the snowflake setting on the CTEK 4.3 when charging the yellow top, in the CTEK manual it suggests to do this for Optimas. There's also "conditioning" charge mode, they suggest to do once a year. I've yet to do that, maybe should though.
  10. spacecar1
    spacecar1 Junior Member
    Denver, CO
    So I know this is a super old thread, but we just replaced the 12v in our 2008 Prius for the first time in 13 years. About 195,000 miles on the car. It probably needed replacing about a year ago, but it was driven minimally (maybe 4000 miles) in 2020 so we didn't realize it. Total cost for new battery plus labor in the Denver area was $275.39 at the Toyota dealer. Just wanted to toss this out there in case anyone is wondering!
    chinarut and Steph1972 like this.
  11. VicAnts
    VicAnts New Member
    Sacramento CA
    2022 Prius
    L Eco
    Just swapped the original Lead Acid 12V battery in my 2022 Prius L Eco. I have approximately 85k miles on the car and commute 4-6 times per week 145 miles round trip. I purchased the vehicle new in 2022. I got three failures to start in the morning and had to use a jump starter to get the car going. I do have a dash cam hardwired with an auto cut off switch so that’s not the issue. I also have a Coma 3X which is hardwired and does upload my drives via WiFi when the vehicle is off so that may be contributing. The test at one AutoZone showed battery failure with low cranking power while another test at a different AutoZone showed low voltage, needs charging. I decided to replace it with the Duralast Platinum Absorbed Glass Mat (AGM) Battery 140R 570 H4-AGM battery as it has a significantly higher cold cranking capacity but I can’t help but wonder if I should have simply tried trickle charging the old battery. Also, should I remove the new battery and trickle charge it just to make sure it’s fully charged? I figured my commute is long enough to get the battery fully charged so that shouldn’t be an issue but I am not 100% sure.
