12v battery - is it time to change?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cybervic, Apr 19, 2017.
  1. Cybervic
    Cybervic Junior Member
    East Sussex, UK
    Hi everyone, Prius Newbie here from UK. I have just bought a Prius 2 last week, 2007 T-Spirit model, has FSH with Toyota and was last serviced Nov/2016 at 82500 miles.
    I am slowly learning about Prius, and was checking out diagnosis menu 2 days ago. To my surprise, 12v battery voltage reads 9.3-9.8v. Toyota confirmed that there is no record of 12v battery ever replaced. In my previous cars, any battery that reads below 10v would have all sort of problems so I’m rather confused if I am getting the right reading. The Prius drives well, has no warning sign, goes to Ready mode straight after hitting Power button. Computer shows average 45mpg. (I've so far done 370 miles which 2/3 of it were motorway, and used 40 litres of petrol).
    so my questions are:
    1. Can I measure the voltage on +ve and -ve terminal like any other car battery using multimeter to ensure 9.xV is the right reading?
    2. I have turned off audio, light, aircon and dash cam, Is there any other things I should turned of to get a correct reading?
    3. Toyota quoted me £115 to replace the battery with OEM one, I am wondering if there are cheaper battery with higher capacity that I can replace myself? Can anyone recommend one? (the yellow top battery cost around £180 in UK which is too expansive for me.)
    4. As it was serviced 5 month ago in late Nov/16, shouldn't a low voltage battery been picked up during the service?
    Thanks in advance.
    Vicky
  2. Mendel Leisk
    42,347
    Yeah I would go with your #1: connect a digital volt meter, either at the jump-start point under the (erh) bonnet, or directly at the battery, to see where you stand. Anything under 12.3~12.4 volts, it's near-dead. And assuming it's the original battery, time for replacement. £115 seems reasonable, installed.
    52,855
    congrats and welcome!
    test it after the car has been off a few hours, to remove surface charge. all the best!(y)
  4. Patrick Wong
    18,210
    6,517
    Regarding question 4, unless the battery was on a list of items to be checked, my answer would be "no". If you are lucky a visual inspection might have been performed looking for corrosion on the terminals.
  5. Cybervic
    East Sussex, UK
    Thanks everyone,
    I did another reading with multimeter and it's 9.6v.
    It had a Gold service last Nov, and "check battery" is included in the servicing content. Is there any ground for me to question them about not picking up battery problem?
  6. bisco
    52,855
    check the 12v, or the hybrid battery? and if it is the 12v, does that service mean they will replace anything they find bad for free? or would you have had to pay for a new 12v?
  7. Cybervic
    East Sussex, UK
    I checked the 12V battery terminal with multimeter and it read 9.6v.
    The last owner would still have to pay the battery of course. Few years ago, toyota failed to pick up a thin brake pad for my last car and when I found out after doing a MOT, they replaced it for free.
  8. bisco
    52,855
    i understand that you checked the 12v, but i'm asking if they checked the 12v, or the hybrid battery.
    that's a good deal, but how do you prove it didn't go bad after they checked it, shouldn't there be a spec on their report?
  9. Cybervic
    East Sussex, UK
    in UK, all the car of 3+ years old needs to pass roadworthy check (called MOT), I had car serviced 2 weeks prior MOT and it was picked up during the MOT that my brakes were thin. Service report mention nothing about brake.
  10. bisco
    52,855
    interesting, it's amazing the car even starts at that voltage. where do we go from here?
    WilDavis likes this.
  11. Cybervic
    East Sussex, UK
    I don't know, that's why I need some help here. if it may drop dead suddenly then I will have the battery replaced, but if I can hang on until a warning sign comes up then I will wait. Any ideas?
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Time for a new AuxBattery! Normal life is around 4 to 5 years! Failing/dead AuxBattery can cause all sorts of other problems which on the face of it, might not be obviously related to 12V. Replace battery and other problems might disappear! Good luck!
    bisco, Cybervic and biglew8 like this.
  13. Mendel Leisk
    42,347
    Do you really want to take that on? (n)
    Two weeks in, you may have a case. Maybe give it a try. Maybe agree to 50/50? Was this private purchase, or through dealership, with some sort of warranty?
    Dealership service departments say they check everything, reality is somewhere between what they claim to have done, and nothing. Worst case: they just are checking a lot of boxes without doing anything.
    Regardless of their responsibility to check the OEM battery, it is a "consumable", ie: something the owner is responsible for replacing. Sometimes replacement batteries come with warranties, Toyota USA for one, but I'd suspect they're pro-rated, and debatable: it's just too easy to run a battery down. And regardless, batteries last 4~6 years.
    Someone in the UK just yesterday said they were quoted around 110 euros, for a new installed battery. That's reasonable.
    12v battery - is it time to change? | PriusChat
    ^ Hah, that's you, lol. :ROFLMAO:
    Oy vey, I'd stand by my earlier advice, in your other thread. Just get a new battery, they're offering a good deal.
    #13 Mendel Leisk, Apr 20, 2017
    bisco, Cybervic and WilDavis like this.
  14. bisco
    52,855
    if you're sure everything is off when you're getting that voltage, i would replace it.
    there is no warning message, just go/no go. some people get lucky, and the car starts doing weird things like not unlocking doors or getting dash lights. that gives them time to replace it without getting stuck.
    i'm surprised you're not having any issues.
    Mendel Leisk and WilDavis like this.
  15. Cybervic
    East Sussex, UK
    Thank you, I find it really weird that the car starts and drives ok.
    I am deciding which battery to replace at the moment, in the mean time, please do let me know if there's anythings else I have not turn off for battery reading,
    so far I have turned off :
    - head light
    - radio (audio off)
    - air con
    - dash cam (goes via cigarette charger, so plug off)
    Thanks.
    Vicky
  16. mwardm
    mwardm Junior Member
    United Kingdom
    (Just happened across this thread while passing by for something else.)
    If I recall correctly then I read something previously about the auxiliary battery mostly being used just to start the inverter - at which point your power comes from the hybrid battery anyway, so there's plenty of it.
    I don't recall the whole story, but I think my 07 reg gave me a clue that the battery was going bad across the 2015/2016 winter when it refused to start after I hadn't used it for a week. I'd seen reports of problems here but it was no issue through the summer and the (local independent) garage ran a load test and said the battery seemed fine.
    The day our first cold spell of winter 2016 hit I'd parked the car in the work car park. It wasn't much fun to find the car wouldn't start in the cold and dark evening.
    I'd get the battery replaced before winter comes, if I were you.
    (Also: When you've connected up the jump leads and got some power to the car but the MFD display says something along the lines of "there's no way you're driving this car!"... do at least try to stick it in gear and drive it.)
    I looked at the various battery options and couldn't find anything more sensible or economical than getting the battery from Toyota. (With the yellow-top you have to faff around with tubes that don't fit, as I recall.) I saved myself £15 by buying the battery as a spare part and fitting it myself as a matter of principle. It's a bit more awkward to fit than you'd hope though.
    However, if you do fit it yourself then it wouldn't surprise me if, on a 2006, you discover that there's water in the battery well and you need to drain that and then reseal the hairline cracks up in the roof gutters if you don't want ice on the inside in the cold weather.
    (You're only seeing my car's bad side. Most of the time it's lovely. Also, my computer almost always says 50 - 51 mpg over a tankful of petrol. Doesn't seem to matter whether I'm doing in-town or motorway trips. Air-con almost always on... which reminds me, that needs a regas.... :-( )
    Good luck!
    Cybervic and bisco like this.
  17. bisco
    52,855
    sorry we missed this vicky, how did you make out?
    Cybervic likes this.
  18. Cybervic
    East Sussex, UK
    Hi Guys (or gals if there's any) :)
    Thanks for the follow up, here's a bit of update.
    I decided to change the battery 2 weeks ago. Even though it hadn't show any problem, I realised I couldn't drive this car at ease having constantly wanted to know how the battery is doing and worry if radio, air con and/or phone charger would ever drain the battery.
    At first I was in dilemma whether to go for an AGM mobility battery but after spoken to 2 local taxi drivers, I ended up with their recommendation which is a Varta Blue B33 that has 5 years warranty in UK (it's the same company that makes Bosch Battery) . The size is a perfect fit and cost only £45 (as apposed to £115 from Toyota), I fitted it myself and it's quite straight forward following a online guide. I had researched the procedure and knew about the vent tube size problem, some people shaved the tube with a Stanley knife to fit into smaller vent hole on new battery, but I don't trust my craft skill so I had bought a straight hose reducer 5mm - 4mm, it fit perfectly.
    Before changing the battery, my average mpg is about 43mpg but now it's averaging 50+ and I am very pleased with it.
    Naurill and bisco like this.
  19. bisco
    52,855
    congrats! i hope that wraps it up. and a testament against those who claim a bad 12v cannot effect fuel economy.
    Cybervic and jerrymildred like this.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Glad it's fixed. I just now saw this thread for the 1st time. As Bisco said, this really shows how hard the car can be working to keep a bad 12V battery charged.
