12v battery - is it time to change?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cybervic, Apr 19, 2017.
  1. Ivan Davis
    Ivan Davis New Member
    Dorset
    2011 Aqua
    Hi! It sounds like your Prius is functioning well overall, but the 12v battery voltage readings of 9.3-9.8v are indeed unusually low. Typically, a healthy 12v battery should read closer to 12v when the car is off and around 13.5-14.5v when the engine is running. Since your Prius hasn't had the 12v battery replaced since it was manufactured, it's likely due for a replacement. Even though the car is running smoothly now, a battery at that voltage could potentially fail unexpectedly. It would be wise to get it checked or replaced by a professional to avoid future issues.
    WilDavis likes this.
  2. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    current prime gen 3 (2020?) battery cost at Toyota dealership??
  3. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    Each dealership is different. Why not call your local dealer and find out for yourself?
