12v battery keeps getting discharged
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by D Huynh, Jan 15, 2014.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep, thats a real killer on a small battery. :(
  2. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    I guess I'm not quite following. Are you saying that on all our PiPs the dome light is constantly on, lighting the interior? Maybe a better question is, just what is the dome light, the tiny beam that illuminates the shift lever and center control buttons, or the light over the rear seats? Thanks.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    The overhead map lights right and left, If you forget to turn them off they will stay on.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    The map lights will not shut off when you close your front doors doors.
  5. Michael999
    Michael999 Junior Member
    Eastern Ontario, CANADA
    Hello,
    I'm intrigued by your situation.
    1. If you noticed that when the dealer replaced the 12V battery, that your EV distance returned to the same value when the car was new?
    2. Since then, have you seen the EV distance start to decrease again?
    3. What is the average temperature overnight where you are?
    4. When you charged the battery, did you disconnect one of the leads as the manual states? Seems over cautious but may be for a good reason.
    My battery was replaced, under warranty, but with no explanation. I have recently purchased a 12V battery warmer to see if this will improve my situation.
    As for the appearance that the EV battery got charged overnight...The EV battery actually charges the 12V battery under normal conditions. A defective 12V battery will show therefore reduced EV range of the traction battery, draining the larger battery. If the 12V is replaced or recharged (i.e. overnight), then there is no longer a "burden" on the traction battery, making it appear that the voltage/EV range has been boosted, which is not the case.
    Michael
  6. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    This is a reasonable guess, but I don't think that the car ever charges the 12 volt battery while it is off. Accessory battery failure is common in the Prius models, in part because of this.
