12V battery life
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Beale, May 31, 2013.
  1. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    We know from users experience the 12V battery lasts from about 3 to 5 years.
    So I had to find out what affects the life and why the variation.
    I noticed in previous vehicles that "sealed" lead acid batteries started to give warning signs after 3 years. I pried them open (often just pealing off the label allowed access to removable fill holes - they DO have to fill them at the factory!). I added distilled water. Problem solved. They lasted over 6 years.
    So when Pearl's battery started to indicate "end of life" I did the same. Yes, it's an AGM, but it's liquid in the mat so I added distilled water until it was showing just above the mat. Being careful with the label allowed me to put it back, remaking the "seal". Pearl's original battery is now 6 years old and the new owner reports it's still going strong. It was kept on a "battery tender" over last winter, while connected in the car.
    In hot climates you may need to add water more often. Here in our "cold" climate people think batteries don't last as long. In fact, while they may not start a frozen car, they can last much longer than ones that are used in a hot climate, if the owner doesn't panic and change it out prematurely.
    My conclusion is they are not "maintenance free" batteries, they are "maintenance impossible" batteries (if you go by the industry desire you not mess with them). Add distilled water as necessary and they can last a long time.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. Former Member 68813
    3,524
    983
    US
    How did it do so?
  4. syscon
    syscon Member
    329
    43
    Edm. Alberta
    My Optima "yellow top" is 16-year old :) paid 250 for it July 1997
  5. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Does it fit in your Prius. :)
  6. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Not easy, I've never try to put it IN but I did rough measurements and I would need to remove just the bracket that hold the current battery and it should go IN
    The one I have is model: D43 750CCA 55AH
    Measurement: 10in (L) x 6 13/16in (W) x 7in (H)
    Though the only the top section is 10in long the middle part is 9 5/8in
  7. David Beale
    5,963
    1,989
    Edmonton Alberta
    After sitting for a day or two the voltage was down lower than normal - around 11.8V or so. When started the voltage was higher than normal and stayed high for longer (indicating to me the car's system was charging it more than normal).
    On other vehicles when really cold starting became sluggish.
    Just adding the distilled water fixed it right up. On the other vehicles (SUVs) I could see the electrolyte level was down. On Pearl I could see the top of the mat was dry. I figured that was probably not a good thing.
  8. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    People talk about doing oil changes more frequently than the 10K interval....I have posted that it does not make sense.
    Now on batteries ...
    I have the opposite opinion.
    I hate getting stuck, and I even hate it more why my wife or daughter get stuck.
    I change mine every three years.
    They are about the cost of an oil change......so they are not that expensive
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Not to start an argument but there was a post here about someone added water to the battery, and the acid boiled over and leaked out, etched through the body metal then into the muffler, then he had an exhaust leak into the cabin!
    Once Toyota determines their sealed batteries were messed with, they most likely will deny all warranty coverage for the damages.
    My opinion is to not screw with something not meant to be screwed with. I carry a rechargeable jump starter, inflator with me, so I am covered if the battery should fail to boot up the Prius, and I can help other people with a conventional drivetrain with a dead battery if needed.
    Bill Norton likes this.
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Here in the desert, you can count on an OEM battery dying after 3 years, and they don't die slow it's all of a sudden on a hot day. You're very lucky if it gives you any warning. Decent after market batteries last 4 years. One of the worst things for a battery is lack of use, they need to be run and charged frequently. But here its the heat that gets them.
  11. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    How are the HV batteries holding up in your neck of woods?
  12. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    No problems I'm aware of. NiM batteries generate their own heat. I'd assume that as long as they are adequately cooled they should be fine. I also wonder if placing the Prius 12v batt in the cabin might extend its life, compared to being wedged under the hood where its 150'+.
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    rdgrimes and I are both from New Mexico, but we have huge climate differences across the state, and micro-climates within counties. I live in the foothills of Albuquerque. I replaced the OEM 12v at about 5 years with an Optima that is still going strong at 4 years.
    David has a very good point. I might try adding some distilled water if it is an easy DIY for my Optima.
  14. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I should have qualified my comments about 12v batteries, since its based on the usual car scenario. Prius 12v batts have a lot less to do in the course of a day. No cranking *should* mean a longer life, but its also a pretty wimpy looking battery. I'd still replace the OEM battery after 3 years just on spec. There's really no way to judge how healthy it is, since it doesn't crank anything. I suppose you could put it on a test meter and simulate cranking, but I've never trusted simple voltage checks. When you ponder the considerable hassle generated by losing the 12v on a Prius, it seems a good idea to err on the side of caution.
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    I check the voltage with a multimeter after the car has been parked for 6 - 10 hours. No worries. IIRC replacement time (or perhaps refilling time) has arrived when the result is < 11.5 Volts
  16. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Is it made by Panasonic? I have had very good luck with Japan built Toyota's Panasonic 12Vs going into the 7 - 8 year time frame, under the hood cranking. It gets to 105- 110 here in the summer.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Compare the speed of the power windows in IG-ON and in READY.
  18. Launch Vehicle
    Launch Vehicle Junior Member
    82
    Missouri
    clever. VERY clever. Thanks!
  19. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The 12V battery isn't under the hood. It's in back, under the cargo area.
    SCH-I535
  20. Den49
    Den49 Member
    498
    272
    Maryland
    After four years and 60,000 miles, my 12V battery reads 12.6V at rest and shows no sign of weakness or imminent failure. I have cleaned the battery terminals twice during this time. I do not plan to replace it prematurely and expect it will last two or three more years.
