12V battery problem
Discussion in 'Gen 2 Prius Main Forum' started by medicis2, Nov 1, 2020.
  1. medicis2
    medicis2 New Member
    Montreal Canada
    Please pardon the long story. I thought details might help with a diagnostic.
    After parking quite normally overnight, I unloaded some stuff (doors open maybe 5-10min) then I vaguely remember not seeing the flashing lights when locking with the fob, which would make sense because I had no problem opening the door an hour later, just to find the battery dead as a doornail. No "ready" light. I turned the visor light on to confirm: faint glow for just a few seconds.
    No access to the 12V battery. So I tried to charge it via the jump start posts. My charger immediately went into overload protection (current way over 8A). Needless to say, I stopped instantly and did not consider a jump start for fear of shorting my friend's battery.
    An ohmmeter test across the same posts shows no short at all, infinite R. (???)
    Is it usual for a dead battery to exhibit a short circuit? This would be the better news.
    Or is the short elsewhere? Ouch!
    I hope the electronics have not suffered from my charging attempt. I guess they were disconnected: the fob was NOT in.
    I would appreciate any insight you Prius gurus can provide before I "invest" into towing... Thanks.
    Philippe
    Prius 2007
  2. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    Check your fuses... If you jumped with reverse polarity you may have caused some damage, but not too serious... If you google search "reverse polarity jumpstart priuschat" you can compare your symptoms to others.
    In your owner's manual you can read about the manual rear hatch release so you can access your 12v to inspect all the connections... It's common for people to have problems with the negative battery terminal that connects to the frame of the car. Also I've had experiences after changing a battery where some of the stuff that connects to positive terminal would need a good shake to work normally again. So inspect and tighten everything down if your battery is still healthy.
    How old is your 12v battery?
    52,819
    you can put 12v (not a charger) to the jump post and open the hatch, or crawl in back and pull the manual lever. no need to tow.
  4. medicis2
    medicis2 New Member
    Montreal Canada
    I am positive (pun intended) that I have not reversed the polarity.
    I have changed the battery once in 13 years, maybe 5-6 yrs ago. I know it's due. Just puzzled by the apparent short when charging.
    PriusCamper likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It could be that your battery is just really really dead and you don't have a smart enough charger. My charger checks the polarity before it starts charging and it also allows me to choose the charging current.
    Old fashioned chargers will try to apply charging current without checking the polarity. We've all had brain farts where we thought we did one thing but really did something else. No shame in that. I was going to bring some paper plates to work with me this morning. After I got here, I discovered that I had no put them in the bag. And that's why newer chargers give you a chance to double-check. If you don't have one, it would be a super good idea to get one.
  6. medicis2
    medicis2 New Member
    Montreal Canada
    Oh yes. I have plenty of brain farts but not this time. My old charger has a reverse polarity indicator that remained green and the amp needle went out of scale in the right direction.
    I need a better charger, though.
    jerrymildred and PriusCamper like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Just a note that it is NOT good to try and measure the resistance to ground of a circuit that normally has power on it.
    It is possible that your meter how has a blown fuse in the OHMS section.
  8. medicis2
    medicis2 New Member
    Montreal Canada
    I know it was risky. I measured the voltage first: zero. I thought it would show if there is a short somewhere across the battery terminals.
    Ohmmeter is still alive, proof the battery was really dead, but I agree it's not the best way to prove it...
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    That wont hurt your ohm meter. Just wont read right. Theirs no fuse in the ohm section.
    This dead battery is the perfect scenario that has blown up many a G2 Prius over the years.
    Typical scenario we have seen many times is the 12 battery has been so perfectly and deeply discharged by a light bulb left on to 0 volts which does really present a dead short to a charger load wise.
    Along comes a AAA tow truck with huge battery jumping current capability much more power than a normal car. They hook up the jumper cables to the Prius and wham there's a massive inrush of current across the 12 volt buss. A surge the Prius 12 volt buss was not designed to handle.
    Expensive hilarity sometimes ensues.
    Lucky for the op his pos charger just said nope.
    This is why if I'm out and get a dead 12 and I don't have a voltmeter with me to see how dead it really is (but turn on the headlights if no headlights at all be aware your in dangerous territory) I would never ever get a jump start. Its getting towed home I got AAA so i can take the 12 out of the circuit and charge or replace it.
    This is why we used to see so many AAA jumps that would blow up the car. Hard to believe that many AAA guys hook up jumper cables backwards but I don't think they are. Its the car and a flat dead shorted little time bomb in the trunk.
    100% dead battery and an AAA jump can be lethal to your wallet with a G2.
    Btw, when that little 12 is perfectly discharged it sometimes damages the battery. If its a few years old just get a new 12 volts.
    #9 edthefox5, Nov 4, 2020
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    Overall a good post, Ed.
    But you still are having a problem with stating facts that are just simply WRONG.
    The OHMS section of most meters is the ONLY place where there IS a fuse.
    If the meter also reads current, there is another fuse there too.
    IF you stick an ohmmeter across a voltage source, something will blow.
    If there is no fuse, something else will go.
