12V battery question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jackmccullough, Dec 18, 2021.
  1. jackmccullough
    jackmccullough Junior Member
    45
    Montpelier, Vt.
    Yesterday my second generation Prius died on the road. When the wrecker arrived, and after blocking traffic for an hour, I was able to get a jump and be on my way.
    I think the cause was that I ran out of gas, and I've added gas to the tank. I let the engine run for half an hour or so and I've been able to start it a couple of times since then.
    Because we know that the 12V battery is one of the vulnerabilities of this car, is there a way to test the battery to find out if I need to replace it rather than waiting until it strands me again?
    TIA.
  2. JC91006
    16,480
    8,397
    Yes there is a way to test it. Any of your major auto parts suppliers will be able to test it for free. Just go in and ask them to test the battery.
    The rule usually is to replace the Prius battery when it's over 6 years old. That way you know you're covered
  3. Mendel Leisk
    38,705
    Go to Amazon, search for "12 volt battery tester".
    I've used a Solar BA5 for over a decade, their current iteration is BA9 I believe. Ancel seems very popular, no experience with it though:
    alftoy likes this.
  4. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    As suggested by Mendel - 12 volt digital battery tester. Mendel has an Amazon Canada price
    Clore Automotive BA6 and BA9 - $53 an $49 USD respectively on Amazon.com
    Clore Automotive Digital Battery Testers
    #4 alftoy, Dec 18, 2021
  5. Mendel Leisk
    38,705
  6. bisco
    49,433
    just get an inexpensive jump pack, and keep it until it no longer recharges
  7. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
  8. MrPete
    MrPete Active Member
    424
    172
    Colorado, USA
    Wow. Every six years? Our Gen III is over a decade old. I *am* looking into replacing the 12v soonish ;)
  9. Aegean
    Aegean Active Member
    427
    187
    Alexandria VA
    Battery life for the Prius depends on location and how much heat or cold is exposed. For example in a southern state or northern state might be 6 years and in a state somewhere in the middle 10 years. In Virginia with significant garage time I replaced the original AGM battery at year 8 just as preventative maintenance while had life left. Now after 9 years the second OEM AGM battery tested 288 CCA out of 325 CCA and I plan to keep it until CCA drops to 50%-60%. Hopefully 10-12 years lifespan.
  10. MrPete
    424
    172
    Colorado, USA
    I agree fully about environmentals. We get extreme change. Like 50-60 degrees in a few hours on occasion.
    The interesting thing about a Prius is: 12v doesn't start the engine so "CCA" is pretty meaningless.
  11. Aegean
    427
    187
    Alexandria VA
    That’s why battery lasts that long in hybrids. CCA is still a good indicator for SOH and easily measured by my inexpensive conductance battery tester.
  12. JC91006
    16,480
    8,397
    Congrats on the decade old battery, it's had a good run. I have a yellow top battery from 2014 in one of my cars, still going strong. I maintain the battery every half year, give it a full charge 1 night. Maybe I can get this one to go a decade
    The general recommendation of 6 years is for average users that don't pay much attention to their batteries. It's better to change them out before they fail, as a 12v battery change will normally happen only 1 time if you keep the car for a decade.
  13. Mendel Leisk
    38,705
    Yes and no: if the CCA value is dropping I’d say it’s still a good indicator, of a deteriorating battery.
    MrPete likes this.
  14. MrPete
    424
    172
    Colorado, USA
    That makes sense. My next question is: is any third party battery worth even considering? I've started looking and here is what I see in January 2022:
    * All third party batteries seem to come with 2 year warranties, and cost a little over $200
    * Toyota TrueStart has a 24+60 month warranty (the latter is prorated)
    * My dealer has a $30 off coupon; TrueStart would be $234-30=204 plus tax, installed
    This seems like a no-brainer.
  15. bisco
    49,433
