12V battery recommendations?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sambojoho, Oct 24, 2023.
  1. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    I have a 2015 with 82k miles. Original 12v battery. I’m wondering if any experts on here recommend a preventative replacement time for this, or should I rely on a battery test? How reliable are auto shop battery tests? Any recommendations on brand of replacement?
  2. Tombukt2
    Tombukt2 Senior Member
    13,732
    2,485
    Durham NC
    Yuasa or hi grade AGM or gel 12 battery. Yuasa and old Deka are very difficult to find . Sears has a good unit MFD for them blueish label on it. Some of these high-end battery tester that the big box stores are using now are quite costly and put the battery through quite a bit of paces so generally they should be quite accurate.
  3. Mendel Leisk
    42,148
    Test the voltage with a multimeter first thing in the morning, for a rudimentary assessment. With an electronic load tester you can get a much better idea. Solar makes prosumer level ones, and a lot of battery retailers will have one one hand, do gratis tests.
    the fact that it’s still viable is testament you’re doing something right, say frequent/longer drives, and not having accidental drains.
  4. bdc101
    bdc101 Member
    250
    usa
    Agreed - letting the battery die is the best way to kill your battery.
    I would also agree with the suggestion to get it tested. It could die in five years, or it could die next week at this age. I just bought my 2010 prius with 262k miles and the original battery, so it could certainly give you a few more years! But there's no way of knowing whether it's next week or 5 years unless you get it tested.
  5. bisco
    52,662
    8 years is a good run. either replace it with an oem, or if you want to get the most out of it, carry a jump pack and replace it when it won't start the car.
  6. ASRDogman
    ASRDogman Senior Member
    7,963
    4,046
    Go to the Toyota dealership and get the OEM battery. It's the BEST one for the car.
    They get a 4 amp agm charger and charge it for 8-12 hours so it is fully charged.
    They do not charge them at the dealership or any other store.
    Doug McC and Ryan Will like this.
  7. Doug McC
    Doug McC Senior Member
    1,087
    427
    Midwest
    2022 Prius
    If you can afford the luxury of a dead battery then run it to death. At 8 years you have had a good run. I bought a Topdun BT100 battery tester (The Car Care Nut recommended the brand (he tested the BT200 which has a 6 volt setting that the 100 doesn’t)). Nice thing about it is it shows you the Internal Resistance so you have an idea of how well it can perform and you can track it.
  8. Mendel Leisk
    42,148
    Solar BA5 here, no complaints. Current is BA9 I think.
  9. tak1313
    tak1313 Member
    MA
