12v battery replacement 2021, worth getting the (smaller) OEM?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tangerino, May 1, 2021.
  1. tangerino
    tangerino Junior Member
    82
    16
    WA
    Hi all,
    I have an aftermarket 12V battery from Advance Auto Parts (Diehard) that looks to be having trouble holding a charge. Had to replace it under warranty after 2 years, and now the replacement is getting weak (11.5V when starting). I drive a lot less these days but I tried to treat this replacement better with weekly driving, carefully monitoring the voltage on startup (via cigarette lighter port), and trickle charging as needed. Maybe this brand of battery just isn't very good?
    My battery was reading 12.6V new, but the voltage it holds after charging has been steadily dropping every few months - 12.4V, 12.2V. Now even after an hour of driving it won't go above 12.0V at best. It's always in the 11.* range now. The lowest I've seen it was at 11.3V and I put it on a trickle charger immediately, but maybe it was already permanently damaged/sulfated at that point? In ready mode I get 13.9V-14.1V so the charging system seems to work fine. I was considering trying a battery-reconditioning charger like a CTEK to try and revive it, anyone had any luck with that?
    If not, any recommendations for a good battery replacement in 2021? I know the Optima yellowtops used to be popular (prior owner of mine had one) but apparently quality is way down now. Should I just go with an OEM replacement these days? I have the non-SKS Gen 2 Prius so I don't like how small the capacity of OEM is, but maybe the 7-year warranty makes up for that (and it looks like Toyota will cover towing/labor if need be).
    I was also considering trying a cheap $20 U1 wheelchair battery but wouldn't want to end up damaging some electronics or losing power while driving. But it would be nice to not have to shell out $150-250 every year or two if my Prius (and/or driving habits) just chew through 12V batteries...
    I thought about parasitic drain but have no idea where that could be coming from (since the cigarette lighter ports aren't powered after the car turns off and I always turn off headlights, shut all doors, etc). I did check the voltage change overnight and saw maybe a 0.05V decrease over 12 hours. Is that normal? I know at that rate sitting 2 weeks would totally discharge the battery (12.6->11.4V).
    52,390
    your problems all stem from lack of use. whatever battery you buy, invest in a maintainer instead of a reconditioning charger.
    most here have luck with any battery, i wouldn't say any of the them are bad. maybe optima had a bad run, idk. but i don't think that is the case currently.
    i put in a new oem for $200.
    i don't think the battery size matters, because without sks, your car is drawing less current when off than an sks car.
    a battery without vent will work fine. (wheel chair, lawn tractor, etc) you just have to be comfortable with the one in a million possibility that it might off gas inside the car in the event of an accident.
    Mendel Leisk and tangerino like this.
  3. Pdaddy
    Pdaddy Member
    160
    49
    The Toyota brand from the dealer may be the best bet. Designed for this vehicle. I got mine cheaper than any other brand from the dealer.
    SM-G960U ?
    tangerino likes this.
  4. ETC(SS)
    7,352
    I usually lean away from dealers when replacing batteries, and this is 2021....not 2005.
    Cars are a little different now, and it's not at all unusual to find models with batteries that are not in the engine room, and electrical systems that place more and more demands on the 12v battery even when the car is not booted up. More and more cars also rely on a specific state of charge for the start battery before they will close relays and or satisfy logic gates and begin the start sequence.
    Back in the old days, it was just a switch, a solenoid and a big honkin electrical motor.
    2 pieces of good news:
    1. Once your car is booted up, the aux (12v) battery is just cargo. The Prius provides some (re)charging current but between the ICE, the motor/generators, and the regenerative brakes....your car isn't really depending on the 12v battery for much of anything at all.
    B. It's extraordinarily hard to gauge what kind of problems are keeping you from giving your battery a third anniversary card, but in the end it doesn't matter if you're using the over-priced OEM battery OR a re-manufactured Walmart special if there's a parasitic draw that keeps flatlining it.
    This is a chronic condition - not an acute illness.
    It may be something as simple as leaving the keyfob in the car if you park in a garage...or a mouse-chewed wire....or a long-forgotten fender-bender that grinched a wire.....OR
    "D: all of the above."
    AND...the car isn't young any more.
    I will leave any comparisons to geriatric persons one might see in the news or on TV to the reader's fertile imagination....
    As mentioned above by @bisco a "battery tender" will treat the symptoms - and for a 16-year-old car that might be as good as a cure.
    ACTUAL mileage may vary.
    #4 ETC(SS), May 1, 2021
  5. tangerino
    82
    16
    WA
    So I have been using one of these $20 3A maintainer/trickle chargers from Walmart to charge it occasionally when it's gotten low: EverStart 3A Portable Smart Battery Charger and Maintainer with Digital Display - Walmart.com - Walmart.com
    Before that I'd just let the car idle (fortunately the ICE itself doesn't usually need to turn on) about an hour (or two), but that didn't seem to charge as well as letting the trickle charger work overnight (3A*12hr = 36Ah). This worked great before but now the charge just isn't really holding as well as before. Seems to top out at 12.0V (after letting surface charge dissipate)
    I hadn't thought about a mouse-chewed wire; maintenance records for this car (it's a retired fleet car) mentioned that's happened before. I guess I could try to hunt that down with a voltmeter on the fuse box, like this? Testing Parasitic Draw via Fuse Voltage Drop Replacing the wires shouldn't be too hard, but it might turn into a wild goose chase finding it.
    The other thing I was thinking was to install a secondary 12V (maybe a cheapo U1 lawn mower battery, ideally 30Ah+) and wire that up in parallel with my main 12V, just to give it a little extra capacity so I don't have to micromanage the voltage quite so much. Reasonable idea? Or would that just ruin the newer one since the two don't have balanced voltages? (not sure that applies to lead-acid batteries)
    Something like this (minus the relay since I probably won't try to use it as a camping power source):
    I guess all in all it's not a huge problem since I carry a lithium jump starter battery with me. It just pains me a bit to have such an expensive 12V battery die so quickly :/
    #5 tangerino, May 1, 2021
  6. tangerino
    82
    16
    WA
    So I've been driving the car a few times a week regularly and on longer trips the last ~7 months, but sadly I've lately been seeing the voltage (under starting load) drop to 10.9V. Winter's probably not helping.
    I've been using a 3A maintainer to fill any gaps if I don't have a longer drive every few days, and I've noticed that the charger reaches "90%" or full much faster than before (<2 hours). The resting voltage drops rapidly from "full" and settles down to 12.45V, and that drops steadily to 12.1V just sitting for 24 hours.
    So the real capacity of the battery is just almost nothing now, not long for this world now at just 16 months old :( I actually took much more care to keep it either regularly driven or on a 3A charger than my previous battery (AAP Autocraft battery).
    Putting it on a maintainer every other day is a chore and I assume it's badly sulfated by now; I could try to recondition it but then again its capacity was pretty mediocre even when new, so I figure I should just let it drain down and look at replacements at this point? I do have a jumper pack in my trunk so not a big deal if I have to jump it for a while.
    I'm really micromanaging my 12V at this point if it's not obvious from the post, so going forward I'd really like to not have to worry about my battery every other day. I really wish that putting it on 3A charger overnight (or doing a long drive) could buy me at least a couple of weeks of capacity. In the winter, I rarely drive on any longer trips and may have holiday travels, so it would be a battery-killing circumstance pretty much every year.
    There has to be a better way? Thinking I need a battery with a lot more reserve capacity to avoid these kinds of problems and mitigate any parasitic draw issues I might have on this thing. Thinking these options at this point:
    1) A LiFePO4 battery (saw Jack's DIY 12v lithium LiFePo4? less drain thread).
    + Much better depth of discharge and won't suffer permanent damage if it had to drain down to say 25% capacity on occasion.
    + Small, light, compact
    + Could DIY with enough cells to probably reach 70+Ah(?) capacity and still fit in the battery well
    - unclear safety, although LiFePO4 should be
    - unclear longevity, whether the Prius inverter will charge a 12V lithium battery properly over years. may need separate BMS hardware?
    - most difficult to DIY, will need to solder unless I buy something aftermarket like a Ohmmu (but that's only ~40Ah capacity and $350, though it has a 5yr warranty)
    - raises eyebrows at resale
    2) A 55Ah AGM mobility battery per this thread: Fitting mobility 12volt AGM battery. | Page 26 | PriusChat
    + cheap ~$100 upfront, high capacity to handle situations above without sulfation
    + other posters claim lasting 6+ years
    + same chemistry as OEM
    + cheap to replace in the future
    - oversized, need to DIY something with brackets and posts to get it to fit in the tiny battery cavity.
    - risk of unvented battery
    - still have to be careful about sulfation if SoC goes below ~50%, but there's much more buffer before then
    - quality of these AGMs unknown, may be hard to find exact replacements again in ~4 years
    3) an OEM battery
    + great warranty, free tow and install 2yrs, 50% 2-4yrs
    + possibly better quality AGM, may handle deep discharge better than AAP batteries did? AAP batteries may be lower quality like recent Yellowtops
    + best option for resale, convenient, no DIY needed
    - low capacity, non-SKS battery (30Ah?)
    - upfront $240 at dealers around me (WA)
    - may also just get sulfated again quickly, not necessarily better than AAP batteries if sitting long periods. AAP batteries are built by Johnson Controls (quality brand)
    - actual dealer may balk at warranty especially if more than one replacement is needed
    I'm leaning towards trying the 2nd option. Hopefully the modifications aren't too painful and still keep the battery and connections secure. EDIT: made a post in the mobility 12v thread, install doesn't look too bad! Hoping I can get 3-4+ years out of this next one (better yet 6-8+ years like others in the thread), but for $110 it's definitely worth a shot.
    #6 tangerino, Dec 3, 2021
  7. Mendel Leisk
    41,901
    We're driving maybe once a week these days. Several years back I installed a quick-connect that came with a CTEK 4.3 charger, and I basically keep it plugged in all the time. Helps having secure garage with AC outlets. Current battery is an Optima Yellow Top, installed in Sept of 2015. A Solar BA5 tester says it's like new still: high CCA and volts.
    With low usage, I think that's pretty much mandatory, to avoid a string of dead batteries.
  8. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Two thoughts
    If you have SKS keyless entry, turn off SKS with button on dash
    If parking outside use a battery tender brand solar charger.
    tangerino and ydpplqbd like this.
  9. tangerino
    82
    16
    WA
    I have the non-SKS (but with expanded battery tray) so there definitely is some other parasitic drain going on; likely some old/chewed wiring but probably not worth going down a rabbit hole to figure it out; much less replace.
    No garage at the moment; that would make this a lot less of a pain. Lugging out extension cords and fiddling with the terminals makes this really troublesome; it would be nice to just plug it in like a phone someday.
    Thinking with work-from-home, I may as well buy some better 12v hardware (CTEK, load tester) since it looks like even newer cars are having this problem. Just seems to be worse for the Prius given its tiny 12v; I guess big SUVs with beefy 12Vs 100Ah+ have enough reserve to not think about it?
    Solar charger is an interesting idea, but living in WA I'm skeptical if I'd get enough light in the winter when I most need it. Still, maybe a $20 5-10W trickle charge is all I need to offset the parasitic drain; and at <1A current, it's probably safe to charge with the electronics still connected, right? Seems to be according to this thread: 12V Solar Battery Charger | Page 2 | PriusChat
    Looking at it now, the panel is smaller than I thought; 7x11 or 9x13 would be a handy size to keep in the hatch, would it get enough light in there though? Sounds worth a try, though not sure I can rely on it year-round. (Plus it could come in handy for summer camping, maybe powering a cooler?) Looks like others have had success with this in NY/Canada: 12V Solar Battery Charger | PriusChat
    #9 tangerino, Dec 3, 2021
  10. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    To update those who may have seen my post in the thread referred to above, I am now using a couple of the panels shown below:
    The AllPowers panels are still functional, but after sitting in the sun for a couple of years, I noticed that the surface on one of them seemed to be a bit degraded (i.e. the plastic covering the solar cells is becoming more opaque, rather than completely transparent as it was when new), which leads me to believe that it may not be able to capture the sun's energy as efficiently as in the beginning. For the record, I did not notice at any point that the AllPowers panels, even the one that seemed to degrade, were failing to keep my batteries charged, but when I saw the Renogy version had the same wattage, was $10 cheaper, and can be wired to the battery terminal without using clamps to allow for a "quick connect" system, I decided to give them a try. Of course, there is no guarantee that the same thing will not happen (surface degradation) with these panels after a couple of years, since they also seem to have a plastic covering over the solar cells. I should also note that the Renogy panels are wider than the AllPowers panels (the dimensions listed on the Amazon site are incorrect, I believe), but they will still sit on the dash of our cars, if need be, although of course it is preferable to have them sitting outside of the car. (On one occasion, I left our Gen 2 sitting in an airport parking lot for 2 1/2 weeks with the AllPowers panel on the dash, connecting it to the front jump points by running the wire between the door and the door frame, and at least for that period of time, the battery still had sufficient charge that I did not need to use my jump pack upon returning).
    #10 davecook89t, Dec 3, 2021
  11. tangerino
    82
    16
    WA
    Glad to hear they both seem to be working out for you so far! I can't see what you linked, but I just bought a 10W unit from Renology, is that what you got? It's on sale for $16 on their direct site so hard to pass it up at that price: 10W Solar Battery Trickle Charger Maintainer | Renogy Solar It's my first foray into solar; seems perfect for this use case.
    I may still end up starting over with a new 12V since this one probably has ~10Ah of actual capacity at this point. Will see how it goes! If all goes well, my next 12V will probably last for the remaining lifetime of the car.
    #11 tangerino, Dec 3, 2021
    davecook89t likes this.
  12. davecook89t
    1,092
    826
    Four Touring
    You got an even better deal!:)
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,088
    1,997
    NJ-USA
    Do whatever works for you. I have had very few problems using 45Ahr AGM (for SKS gen2) made by East Penn manufacturing- they sell under Deka, Napa (at least their AGM), Federated Auto parts, (I believe Duracell's AGM as well).
    I would suggest having a key off draw test done to see if you have something pulling current when it shouldn't.
    You may want to look closely at the manual for your charger- AFAIK SGM batteries are sensitive to the max voltage that they receive. Some budget chargers just "spit out" a fixed amount of power- low volts at high amps (when internal resistance is low) and high volts at low amps (when the battery's resistance is high). Too many volts can degrade a AGM. What's needed is a "smart" charger (one that specifically states it can be used on AGM) that can limit output to what the AGM can accept.
  14. Mendel Leisk
    41,901
    With my CTEK 4.3 the manual recommends a setting with higher voltage, for Optima's. I've been using that setting with the Optima Yellow Top I've got in there(pretty much 'round the clock, with our protracted down times), and so far so good. It was installed September 2015, and still in the pink.
    I don't profess to know much about this; this is just what the manual said, and I've gone along with it.
  15. mr_guy_mann
    4,088
    1,997
    NJ-USA
    That sounds like a smart charger- one that can supply more power during the "bulk" charging phase, then detect when the battery SOC is high and shift to a lower "float" voltage.
