12V Battery Replacement Procedure?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by EZW1, Jan 2, 2022.
  1. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Gonna need to replacement my battery soon. The mechanical part is easy, but wondering about systems. After new battery is in, are there any setting in systems I need to do, or will everything come up normally like nothing never happened? Thanks
  2. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    If you didn’t maintain power to certain systems like the radio and auto window closers, you may have to reset them. Otherwise, just drive away.
    Montgomery likes this.
  3. Mendel Leisk
    38,644
    After intentionally disconnecting (typically for DIY brake service), I’ve noticed some disconcerting behaviours, likely unavoidable. First time I start up, it’s “uh oh, every trouble light is on. Shut down and restart, and that goes away. Then, for the next maybe four start ups, an unusual rev up, something recalibrating.
    yeah but use a memory saver and you avoid this. I use a purpose-built cord that goes between a jump pack and the OBD port, avoids the issues.
