12V Battery Replacement Recommendation
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tonydavid, Jan 8, 2021.
  1. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    We only can see 12.6V or above when everything is off for few minutes or open voltage (disconnected) from any load.
    OBD2 scanner can also read on ACC mode, but the car is already under some load. Healthy battery normally is always above 11.5V on ACC mode. During the startup, as long as it never drops below 10V, the car will not complain. Once at any moment drop below 10V, we often got Christmas lights or all kinds of code including ABS C1241 code, or transmission problems code.
  2. johnHRP
    646
    191
    KA, DE
    Excel
    Just an update from European forum (UK/Ireland and Germany forums). Most of us who have 3rd gen Hybrid (Corolla/Auris 2010-2018) in Western Europe never have issues with 12V battery even though they are already 13 years old. But most of them drive the car regularly.
    typical voltage reading in the car is 12.9V when we charge it externally and about 12.2 V after couple weeks not driven. Typical votlage reading is 12.4-12.6V most of the time under normal usages.
    Mine is now 8 years old and read similar voltage since 2 years ago, 12.4-12.6V in self charging mode. Only when I charge it with LIDL 5A charger, it can reach 12.9-13.V when the charging is finish.
    So, yes, the Yuasa AGM battery can last more than decade if we drive regularly and we live in mild weather or garage kept.
    Spike7 and Wolverine88 like this.
  3. Spike7
    Spike7 Junior Member
    Toronto
    Just a couple months ago I was thinking how long this battery has lasted without any issues. Tonight she refused to start for the first time . I think I'm going to replace my 2012 prius 12v battery with an OEM Toyota battery. 4 months shy of 12 years old. I'm impressed with the longevity. Never had a battery last this long in any car I've owned. Standing "O" to Toyota.
    Oldwolf and ColoradoBoo like this.
  4. Air_Boss
    Air_Boss Senior Member
    4,261
    1,197
    New Yawk
    Impressive. On borrowed time for at least 7 years...
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    Wow that is amazing! Looking at my maintenance records, our batteries have lasted 4-5 years before giving up the ghost.
    I keep testing my wife's 2017 12-volt battery but still showing it's at 98% of life. (Lives in the garage so no extreme temps.)
    Air_Boss likes this.
  6. Air_Boss
    4,261
    1,197
    New Yawk
    Ours, likewise, with Toyota, Optima and Bosch batteries in the v, and Honda, Optima, and Duracell batteries in the CRV.
    An Odyssey dry cell battery in the sports car has the best longevity, so far, at 8 years and still going.
  7. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    My 2016 V, built late 2015, still has the OEM battery in operation. A few years ago my dealer ran a load test on it and said it passed.
    In the back of my mind, though, is the nagging feeling it could fail at any time.
    So that is why I travel with a jump starter.
    I'll probably just have the dealer install another OEM when it fails.
  8. johnHRP
    646
    191
    KA, DE
    Excel
    Everyone should always have jump-starter. It costs about $50 from known brands. The OEM battery last 8-15 years depends on how regular we use the car and how hot the temperature we live. Garage kept OEM 12V Prius often last more than 10 years.
    My neighbor has 2010 Prius and the 12V battery is still original at 230k miles. It burns oil for about 1Q per 8k miles, but he rarely do short trips. Mine is 8y old and everything is still original except tires.
    Oldwolf likes this.
  9. Wolverine88
    Wolverine88 Junior Member
    Canmore, AB
    2015 Prius v wagon
    I always carry a booster, and I have used to help others boost their ICEs. Our 2015 v doesn't get used every day, and most of our trips are 10 minutes or less. It had some issues starting in cold for a couple winters, after mostly sitting during the covid shutdowns. I learned from these forums to use a charger, but didn't do the required maintenance. Last winter, on a -32 C / -25 F morning the car started the first time, but died when my wife turned it off at the daycare. Nothing was working, including the power locks. I called for a tow, but was told it could be 36 hours before a tow truck could come. This motivated me to figure out how to boost the v, and realized it was possible, using my booster pack. I hooked it up to the positive terminal in the fuse box under the hood, the other clamp to bare metal, and turned it on. That gave enough power to the car, and I was able to start it. In the end it was quite simple, and I cancelled the tow.
    In the spring, at 178K km / 111K miles, I replaced the original Toyota battery with an OEM Yuasa S46B24R equivalent from Sask Battery. (Hat tip to @Mendel Leisk for suggestion.) I never tested the original, but did notice improved mileage after installing the new battery. I will keep my eye out for a battery tester on sale.
  10. Mendel Leisk
    42,369
    What was the cost from SaskBattery? Was it still GST only, free shipping and no core charge?
    (The latter wouldn't really work for mail order, anyway. What I eventually did when buying through Saskbattery was drop off the old one at a nearby dealership, where we'd bought our '10. I think they get some sorta bounty for them, win-win.)
  11. Wolverine88
    Canmore, AB
    2015 Prius v wagon
    The price in February this year was $239.50 +GST, shipping to Alberta included. There was no mention of a core charge, and I took the old battery to the municipal recycling depot. Perhaps SaskBattery doesn't have the core charge, since they can not accept batteries for return.
  12. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    A perfect example of just what a ripoff the only dealer here on Guam is.
    They want $600 for the same battery, so I use Optima yellow tops instead.
    gggGary likes this.
  13. Mendel Leisk
    42,369
    I figured they don’t want to absorb another shipping charge, just for recycling, isn’t practical.
  14. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    Still have my OEM running in my 2016 V.
    2024 will start year 9 of operation.
    I checked my dealers online price for the TrueStart 84 and found that it is on sale for a phenomenal price of $160 + tax and core.
    I think I will go ahead and order one at that price.
  15. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    I was incorrect. $160 includes tax!
  16. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
  17. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    Turns out the OEM Toyota batteries for the V are made in Japan.
  18. johnHRP
    646
    191
    KA, DE
    Excel
    You can get original Yuasa battery from Autodoc or Amayama. I bought one for €180 few months ago from autodoc and it is made in Japan.
    Use Google shopping to search. It often shows a good price
  19. ClydeSDale
    ClydeSDale Junior Member
    North of St. Paul, MN
    2017 Prius v wagon
    My 2017 v four no longer has a garage to stay warm in so when I was in for a recent dealer oil change I asked about a battery replacement quote. When he stated just south of $500 I dropped my jaw, commented on how proud they must be of OE and said I guess I would do it myself. This service advisor went into a song and dance about how hybrids need a special battery and it requires a vent. I replied that I knew it was an AGM and I knew the equivalent Yellow Top was set up for venting. He lost all credibility continuing his pitch until I gave him the "Talk To The Hand" signal.
    I don't mind paying a little extra for OE but refused to be abused. Fascinated to hear about the EverStart option. I've had good luck with those batteries as long as they were fresh. Thanks for the tip Sergio!
    gggGary likes this.
  20. Centerpunch
    Centerpunch Active Member
    151
    141
    OH / NC
    2017 Prius v wagon
    My original 8 year old battery in my low mile 2017 finally gave up the ghost a few days ago on a 5 degree morning.
    I was looking at $250-$300 batteries at Autozone, Advance, etc., but then went to the Toyota site online, searched for the oem battery, placed the order, will pick it up at my local dealer a couple miles away, total cost with discounts was under $200, including tax.
    Toyota Genuine Parts | Toyota.com
    Update: 30 minutes after I placed the order, I got an email saying the battery was ready to be picked up.
    #100 Centerpunch, Jan 18, 2024
    gggGary and Oldwolf like this.
