12v battery replacement update....
Discussion in 'Gen 4 Prius Technical Discussion' started by DonJuan1943, Oct 7, 2021.
  1. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Thanks to many of you ladies and gents who helped me with my 12v battery situation in my 2106 Prius 3, gray. After numerous suggestions from yall I found the 12v replacement that I needed at NAPA automotive. Perfect fit, best price; and everything was compatible. Price: $152. +tax & core or exch. Group 140R. part #75140R MF.
    I used a trickle charger as a battery tender to avoid losing data in the system, and I used you tube videos. Seems to have worked; and I did not turn the car into a very expensive toaster. Yet. Toyota wanted 175. for the battery and another 100/plus. to do the exchange. Plus tax. I was going to upgrade to a newer hybrid vehicle, but with only 29K on him; why bother?! For cold snow/ice conditions I've got a 2010 Forester, white, 56K, parked on the other side of the garage. It has a new battery too. Again; thank you for your advice and support.
    MPGboss likes this.
