12v Battery ?'s
Discussion in 'Gen 2 Prius Technical Discussion' started by PriusGuy32, Sep 21, 2012.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Yesterday I installed the SIR-TOY/SCC modules in my 2007 Prius (original 12v battery). This involved leaving the doors open for ~30 minutes (dome lights on) and turning the radio on/off several times to test. Then leaving the radio on for 10 minutes to receive the signal from Sirius.
    After it was all installed and buttoned up, I went for a test drive. It was dark out by then.
    This morning when I went to start the car and go to work, it powered up like normal but the red triangle with the "!" came on too - I had never seen that before! I checked my 12v battery voltage, as explained here and I get 12.1v at standing and 11.4v in accessory. When the ignition on, I get 13.6v or so.
    Does this mean its time for a new 12v battery? (n)
  2. John H
    John H Senior Member
    2,208
    558
    Maybe, but you should try giving it a full charge before deciding. The OEM battery is old enough to suggest replacement and avoid the dreaded death by jumpstart.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    The battery is done. last month My car threw the exact sign too when my battery got soft after 5 years of very good battery tender maintenence.
    It happened suddenly. Don't bother charging it becasue it will give you false hope and may be ok for a while and then leave you when you need it most. 5 years is a very good run for that little battery.
    I installed the Optima yellowtop direct drop in. $169.99 at Advance Auto.
    PriusGuy32 likes this.
  4. PriusGuy32
    1,417
    514
    Replaced the battery with an Optima yellow top today. The old one started dying FAST. As a matter of fact, after I removed the OEM battery (original with sticker "0307" on it) the resting volts were 10.1v. Yikes.
    The new Optima Yellowtop had a resting voltage of 12.2v, I had the guy at AAP test it on the spot before I took delivery of it. I thought new batteries should have at least 12.4v, no? The parts counter guy said it was the only one they had and it had been sitting on the shelf since March 2012.
    Anyway, the battery has a 3 year warranty. I plan on monitoring it closely and as always, made a copy of the receipt, put it in a ziplock baggie and put it next to the battery in the trunk. I also filed the original receipt away. If I lose one receipt for warranty or the print fades on the original, Ill always have the other :D
  5. Patrick Wong
    18,210
    6,517
    I suggest that you use a battery charger (10A charging rate or less) and charge up the new battery overnight. A new fully-charged AGM battery should measure 12.9V.
  6. PriusGuy32
    1,417
    514
    Can I hook the battery charger to the battery while its connected to the car? Or should I remove the battery from the car completely and charge the battery?
    I have a boat with AGM's and have a smart charger, so I could let it do its thing overnight (bulk, float, blah blah blah) but I dont want to hook it up with it being connected to the car and find out I blew a fuse or something crazy and not be able to get to work tomorrow!
  7. Patrick Wong
    18,210
    6,517
    Toyota recommends that the 12V battery be removed for charging as a safety precaution. However I don't bother to observe that.
    In a separate post I believe that you mentioned using a 2A charging rate. If that is the highest rate available, it may take you a full day or longer to bring the 12V battery up to full charge, so I suggest you hook up the charger every night for the next few days until your charger shows the battery is at 100%.
  8. PriusGuy32
    1,417
    514
    Thanks for replying.
    The battery charger has three selections for AGM batteries: 2a, 8a and 12a. I selected 8a for about 1/2 hour and then 2a for the other half before I installed it. So you think I should select the 8a and let it go overnight?
    Edit: I just went out and hooked up the charger on 8a. Its indicating a 'sulfated' battery and is doing the 4 or 5 step, whatever it is, to desulfate and recondition the battery... its not looking good for this battery. I think Im going to have to return it and get a new, unflawed, one.
  9. Patrick Wong
    18,210
    6,517
    I've noticed a few recent posts from other PC members who, like you, have received a relatively discharged new Optima. It would be reasonable for you to ask for a new battery to be in better condition.
  10. PriusGuy32
    1,417
    514
    Patrick - in my case, would you return the battery for a new one?
    Problem is, I took the only one they had in stock. The one I replaced is dead. They'd have to pre-order me one, wait for it to get in, then do the exchange because if i brought it back in I'd have no battery at all..lol. Anyways, Im not sure they do things that way. I think they want the battery back FIRST before they order another one.
    OTOH, I reduced the battery charger to 2amp for the night - My "smart" charger was charging that little battery at 15.8v at 8amps (desulfation) and that made me nervous; I dont want to wake up to the charred remains of what used to be my beloved Prius tomorrow morning...lol :eek:
  11. Patrick Wong
    18,210
    6,517
    I believe that the Optima website indicates that the maximum allowable charging current is 10A. However I understand your concern. It is clear that your battery was significantly discharged when it was sold to you.
    Considering the logistics involved in getting a replacement, I suppose that if this were my car, I would see whether the charger can charge up the battery to 100% within a reasonable period of time and if there are no further problems, then live with it for now.
  12. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I would get a replacement you will not be happy if this battery fails just out of guaranty as stated in my reply to you in the main forum.
  13. PriusGuy32
    1,417
    514
    So I go to AAP today to exchange the battery. The same manager that told me 11.9v is "normal" also ordered me the wrong battery!! :mad:
    I had to wait 30 mins while they went and retrieved a battery from another store. The date code on that Optima was 6/12, not much better than the 3/12 date code of the original low voltage Optima, but they tested it and resting volts was 12.75. Satisfactory in my book. Installed it in the parking lot, now I feel a little better about the $149 I spent! Not to mention more confident on the batterys future.
    In other news, Im an expert and removing/installing 12v batteries on the Prius now!! lol
  14. Britprius
    5,194
    1,922
    Also an expert at getting a good one as in not faulty or neglected.
