12V Battery Voltage Management
Discussion in 'Gen 3 Prius Technical Discussion' started by srivenkat, Jun 7, 2012.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hello,
    I was going over the following page that describes deep cycle batteries and a couple of
    things they mention intrigued me:
    Deep Cycle Battery FAQ Capacity
    A couple of statements they make are:
    Also, there is an upper limit - a battery that is continually cycled 5% or less will usually not last as long as one cycled down 10%."
    For longest life, batteries should stay in the green zone."
    The "green zone" in the second statement refers to 40% to 80% SOC.
    Are the above statements applicable to the Prius 12V battery and if so, is there any voltage management logic employed by Prius to make sure the above are satisfied. My understanding
    is that the HV battery will supply a steady 13.6V to charge the 12V battery from the point the car
    is in Ready state until switched off. Would it not cause it to run afoul of the above statements?
    Thanks.
    52,904
    the 12v is not a deep cycle battery.
