12v battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Virg, Jul 24, 2017.
  1. Virg
    Virg Junior Member
    28
    Austin Texas
    Will a 12v standard Duracell "51" battery work just as well as the AGM type "51"? The standard battery is half the price.
    52,915
    yes, if it's the drop in replacement from batteries plus bulbs.
    make sure it has the same dimensions, correct post size on the correct side of the battery, and the vent tube connection.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    How much are your passengers worth?
    The external venting prevents explosive hydrogen gas from building up in the passenger compartment. AGM minimizes sulpheric acid in case of rupture.
  4. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Do it right. Order the 51-440BAGM Bosch Battery from PepBoys online for $133, go down to the store and pick it up same day. Or even have them install it for free - but make sure they connect the vent tube.
    runnyeggs likes this.
  5. Virg
    Virg Junior Member
    28
    Austin Texas
    Thanks to all for the quick answers. I realize the importance of the vent feature and thanks to Navy for the PepBoys source. That's half the price that Batteries and Bulbs quoted.
  6. runnyeggs
    runnyeggs Junior Member
    31
    NV
    That's what goes into my Bimmer. Either BMW or Bosch battery to save a little. For Toyota, I'd go for Toyota or Bosch.
  7. CivicSky
    CivicSky Member
    169
    71
    San Deigo
    I guess it's time for me to change a new battery too because my interior lights dimmed the moment I turned off the car. I have a bad feeling about that.
  8. ChapmanF
    19,063
    They'll always dim a little. When you turn the car off, the system voltage drops from about 13.8 down to the battery's own voltage, which is only about 12.7 at best. That's about an 8% difference, but light output goes by volts squared, so they'll dim by about 16%, under perfectly normal circumstances.
    -Chap
