12v battery
Discussion in 'Gen 3 Prius Main Forum' started by Questo, Apr 27, 2023.
  1. Questo
    Questo New Member
    Indianapolis
    I replaced my 12v, 2 1/2 years ago after the last failed before 3. Thus one seems to be dying too (optima,) Charging is about 14.4. Any thoughts.
    Also any non dealer recommendations for a mechanic in Indianapolis?
  2. JC91006
    16,934
    8,644
    You can get that battery tested at most auto part stores. Don't have to guess at it.
  3. Mendel Leisk
    42,284
    1. How often does the car get used, and typical trip length?
    2. Ever left a door ajar, lights on or similar, run it down?
    3. Do you ever leave the car in accessory mode (one push of start button without foot on brake), or “on” mode (two pushes of start button without foot on brake), for protracted periods. Say sitting listening to radio, or running AC while parked.
    4. Recently had the car in a shop, say for detailing, something installed, etcetera?
    5. Do you have some accessory that draws power while the car is off, say a dash cam for example? Anything else constantly plugged in?
    Consider doing a check for phantom loads; all cars have “some”, but with Prius it should be no more than about 20 milliamperes.
    #3 Mendel Leisk, Apr 28, 2023
    douglasjre likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    We’d be bored here without speculating on anything
    CR94 and Merkey like this.
  5. JC91006
    16,934
    8,644
    I just had a battery on a Lexus GX460 fail on me this week. One day it just wouldn't start, not sure if I left an interior light on. I charged it and it seemed to have worked afterwards. It's only 2.5 years old, original battery from Lexus (Panasonic). However after I charged it I drove it over to an auto shop (Autozone) and they tested that battery to be bad. They told me although it's charged and working, the battery will not have the cranking amps necessary to start the car when it's cold.
    With this information, I brought the car to Lexus and they also tested it bad and gave me a new battery (under warranty).
    ASRDogman likes this.
  6. Mendel Leisk
    42,284
    For DIY, the tester they're using is likely a pro version of something like Solar BA9, relatively cheap pro-sumer level tester. There's other similar testers; this is just the brand I got.
    Review of earlier version, BA5 (the one I've got):
    #6 Mendel Leisk, Apr 28, 2023
    JC91006 likes this.
  7. ChapmanF
    18,964
  8. Questo
    Questo New Member
    Indianapolis
    Yes. Just gave it a good charge and it seems to be holding fine. That is an easy next step.
  9. Questo
    Questo New Member
    Indianapolis
    All good points, sort of came out of the blue.
  10. ASRDogman
    ASRDogman Senior Member
    8,049
    4,082
    I can speculate that! :whistle::whistle::whistle::whistle::rolleyes::rolleyes::rolleyes:
  11. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    You probably realize that that statement exceeds the intelligence level of most PC members, right?
  12. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    I noticed the GLARING ABSENCE OF “Left the hatch open multiple times”!!!!! LOL
  13. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    I'm still dying how pomp and circumstance over here is wearing a lab coat
  14. CR94
    CR94 Senior Member
    2,820
    1,238
    Northwestern S.C.
    To the car, that's equivalent to "door ajar," which he did list. (Should've said "door or hatch ajar or only half-latched.")
    It takes roughly 2 days to severely discharge the battery that way even if no interior or door lights are on. Shorter periods will shorten its life, roughly in proportion to the number of ampere-hours lost.
