12V Battery's Life Expectancy
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rcshaw777, Aug 21, 2011.
  1. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    have u guys seen the guy on utube that uses a capacitor battery ? 6 'supercaps' that start his corrolla --- this is a nearly 'last forever' 12V battery - no water, smaller space , a lot less weight and costs about $35 for the unit and some time makign some casing and conductor connecting ...
  2. Jaswong00
    Jaswong00 New Member
    Chino Hills CA
    I recently bought a 2010 Prius pkg V with 82k miles and I was getting low 40smpg, after doing tune up(new 12V battery, tranny oil changed, motor oil changed, spark plugs changed), I am getting 50smpg now. Hope this helps.
  3. Jaswong00
    Chino Hills CA
    oh btw, i did the battery test before changing the 12V battery, the test shows 11.6V when I hit the start button after the car sit overnight. The load test shows 10.5V with low beam on, heater fan full blast, and dome lights on. I did not want to get stranded someone and I wanted to improve my mpg, so I replaced the battery and did all the tune up...
  4. chronon
    601
    106
    yit is utterly amazing that such a sophisticated machine, with all the computer control inside this car and all the emphasis on MPG , would suffer a 10%!!! decrease in milegae because of the 12V auxillary source fading to black .... it shows that toyota engineering was not caring about the long haul, only short term (bat expectancy 5 years andnew model intro at end of lifetime) -
    what about people that leave there car on , listen to the radio , door ajar, etc. --- i guess they learn the lesson early !!!
  5. Ridder
    Ridder Member
    141
    51
    Netherlands
    When the car is "on" the juice (even for charging the 12V battery) comes from the HV battery.
  6. chronon
    601
    106
    i believe that's true, so then i guess the engine is taking more power (gas) to charge the HV which in turn
    must charge the LV (aux)
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The lifespan will vary by climate and the individual usage pattern. It is a good idea to have the battery load-tested at each oil service with a Midtronics to verify its state of health.
    iPhone ?
  8. Ridder
    Ridder Member
    141
    51
    Netherlands
    My 12V battery has been depleted twice and I suspect it is having a negative effect on FE.
    I have a WiFi OBD2 dongle in the car that is always on.
    Yesterday, after a night rest, I checked the voltage and it was 12.09 Volts.
    Today I took out the dongle and drove for a while to fully charge the 12V battery (I know I don't have to drive....) and to see how efficient I can drive.....it was perfect weather for Prius: low 70's and I only took 60 and 80 km/h roads.
    The result was 3.9 l/100km. (that's 60 MPG I think).
    I drove 30 miles.
    One hour after the drive I measured again and the voltage was 12.47 Volts now.
    The first measurement was with the dongle in the car the whole night.
    The car has 10K miles on it.
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I am nearing 100,000 miles on our Prius and it was purchased 4 years ago. Living on the coast we have moderate
    weather and seldom does temp go past the mid 80's. Winter is in the mid 30-s to 50's.
    I have a scan gauge and does anyone know what I need to do to see if the 12V battery is up to standards. I believe
    the gauge does have a volt meter built in....
  10. chronon
    601
    106
    like the guy said , load tester .. or u could just go to a place like autozone or advance auto and get a free test.. oh wait, not sure they know how to do a hybrid .. part of their test involves running the car on demand - u will have more luck at a larger place with higher volume of cars than a smaller store and low customer count as that one will more likely have a guy that throws his hands in the air ...
  11. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    On some, like my early 2010 Prius (bought in July 09) it does have a removable cap over the valve regulated vents, BUT it's an AGM battery and should not show any electrolyte above the plates. There is a sticker on the battery warning to not remove the cover or add water. Most AGM batteries are not designed to be refilled.
  12. prius cabbie
    prius cabbie Junior Member
    Is this a joke?
  13. chronon
    601
    106
    perhaps
    perhaps this is for someone that has replaced the glass-gel-pack with a regular lead-acid substitute like the mazda miata call number
  14. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    my 2010 OEM battery just quit....I have 72,000 miles on it.....my gas mileage has dropped, so maybe this new one will help that too.....i'm replacing with optima yellow top
  15. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Fun with 12v batteries.
    in April 2014 I replaced my Toyota 12v battery, thinking my low fuel mileage was caused by that. I bought an Exide AGM51JIS battery.(Larger size) It really didn't help much in the fuel department.
    It seemed to have a longer life for discharge though. I did have several discharge cycles on it that winter. It seemed to rebound OK. This fall it had gotten really cold early and he battery went flat. I pulled it and replaced it with the original Toyota battery. I had kept it on a float charger all that time. I'm glad I kept that battery.
    A week later running the Exide battery, the Exide died again with very low temps. (10 F)
    Because I couldn't open the rear hatch, I crawled in back through the passenger side back door, dropped the seat backs and removed the floor cover and plastic tray, placing them sideways over the driver side back seat that I tilted down.
    I have found if you lift the hood and put a battery in the charging posts first you don't lose the clock or radio settings. My chicken dances don't get clobbered either. Please don't allow the battery + wire to short to ground.
    I was able to remove the brake ECU and unbolt the battery ground clamp and +12v battery clamp, and drag out the bad battery and replace it.
    So since I have a warranty I requested a refund.
    I don't want to see that experience again. I'm going to my local Toyota dealer for my next 12 v battery.
  16. Former Member 68813
    3,524
    983
    US
    My OEM mid 2010 battery is still good 6.5 years later. I made care to never deep cycle it. The location of the battery and protection from engine heat is great.
    I think they changed that in new gen.
    #36 Former Member 68813, Jan 6, 2017
  17. Mendel Leisk
    42,239
    I think once you crawl through the car to the back there's a mechanical hatch release switch: you push that and hatch will pop open, dead battery or not. At least there is on 3rd gen, not that sure on 2004. I hate to spoil your fun though, lol.
  18. bisco
    52,752
    if you put a good battery on the charging post, why can't you open the hatch from outside?
  19. Mendel Leisk
    42,239
    We're having too much fun now. :)
  20. lefteye219
    lefteye219 Junior Member
    32
    New Jersey
    I have a 2010 Prius, about 147K miles on it now. My battery hasn't died yet. Had it for a little over 6 years and the battery is still good.
    Raytheeagle and bisco like this.
