12V connection in engine compartment
Discussion in 'Gen 3 Prius Main Forum' started by KAH, Jan 20, 2018.
Tags:
  1. KAH
    KAH New Member
    Thousand Oaks, CA
    I need to attach a 12V device in my 2012 Prius, but in the engine compartment rather than at the auxiliary battery in the back. I understand that for jump starting, there is a positive terminal in the front fuse box and that the negative should should be attached to the engine block. But does this also provide 12V power? Unfortunately I need the power all the time, not just when the ignition is on.
    Is there any possibility of doing this?
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Yes, but make sure there's a fuse in-line with the power you're taking! (…you know it makes sense! :rolleyes:)
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Yes, but you’ll probably drain the 12V, it’s not designed for 24 hour use. The battery only supplies the 12-14.5 volts temporarily to initiate “ready” Its a totally different battery with about a 38 ampere rating.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    There are two good options for 12v constant power available in the engine fuse box. In the picture, there are two open terminals at the back of the fuse box, seen with two push on connectors with red wires. In addition, at the front corner of the fuse box, there is a bolt that you can put a ring terminal under, seen here in the picture with the cover opened, it's the 10mm bolt to the right of the heavy gauge white wire, just below the small screwdriver. 1516493063275.jpg
    darelldd, kc410 and Mendel Leisk like this.
  5. Mendel Leisk
    38,710
