12v dis-connect, effective
Discussion in 'Gen 3 Prius Technical Discussion' started by worrachai, Jul 7, 2017.
  1. worrachai
    worrachai Junior Member
    48
    thailand
    Hello guy
    I'm user Prius 3 in Thailand. I have the question for dis-connect the 12v battery effect. When I dis-connect 12v battery and re-connect again(in case change 12v battery).
    Any setting will be effect?
    Radio(navigator)
    Display(fuel price, memory of running per month, flash light or etc)?
    ODO?
    TripA, TripB?
    Any window setting?
    If it effect, How can I do? please advise. Anyway, Can I change the 12v battery by myself?
  2. 4md
    4md Member
    97
    55
    Sofia, BG
    You can change it and if you're fast, the car won't reset anything. If you can't change it fast enough, trip A/B will be reset (as far as I remember).
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Radio presets will be lost as well.
  4. Prodigyplace
    12,717
    11,849
    Central Virginia
    You can change it yourself but be sure to get an AGM battery that can be vented outside. The 12 volt battery is located inside the car and you do not want battery gasses escaping into the passenger area.
    When you are standing behind the car with the hatch door open, the battery is located on the right hand side of the cargo area.
  5. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Connect a low amperage (1.5A) battery charger to the jump starting terminal in the fuse box under the hood before you disconnect the 12V battery and you won't lose anything.
    Daigi_ and Zulat like this.
  6. worrachai
    48
    thailand
    Thank you very one for answer.
    I got information from Toyota dealer. After re-connect, the automatic window need to setup. Do you know how to do?
  7. Mendel Leisk
    42,355
    If I recall correctly: roll it down, then all the way up while lifting the button the whole time, then continue to hold up for an additional 2 seconds or more. You may or may not need to do this. The last couple of times I've disconnected: no window problems.
    There are ways to retain memories to, google "12 volt memory saver" should get results. I use a special OBD cable with my jump pack.
  8. worrachai
    48
    thailand
    Thank you.
    If, in case of HV battery. Do you recommend to do by myself? I want to check the HV battery healthy.
    In my country, Prius is not popular car because most of driver worry about battery and maintenance fee.
  9. Mendel Leisk
    42,355
    I've done nothing with with the hybrid battery, so far. It is definitely more complex, and step one is to remove the orange "switch", to isolate it. Replacing the switch is a little tricky, you have do several actions, the opposite of removal, but not that obvious.
    Checking and refurbishing the battery is complex, again, I've no experience. But there are people here doing that, perhaps they will comment. Maybe start a thread with hybrid battery in the title, will get more attention.
  10. Prodigyplace
    12,717
    11,849
    Central Virginia
    Working on the HV battery can be dangerous (life threatening) if not done correctly.
    @jeff652 or @ericbecky should be able to offer some advice on your situation.
    Raytheeagle and Mendel Leisk like this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    There are some install videos on Hybrid Automotives website that show how to install the Prolong Harness.
    Prolong Battery Systems. Extending the life of your hybrid. – Hybrid Automotive
    Good step by step instructions ;).
    Did the harness install in a Gen2 Prius a couple of weeks back and also have a harness on our 2010 Prius II.
    Pretty simple to do, but definitely something you need to do with respect for electricity in mind(y).
    Prodigyplace likes this.
  12. runnyeggs
    runnyeggs Junior Member
    31
    NV
    The 12v is behind the rear seat on the passenger side isn it? I think you can connect to it via the fusebox in the front though. I have not checked it out yet. Seems kind of weird but I saw some lady jump start her car that way so I am guessing this is connected to the rear battery somehow. I was thinking of hooking up LED light bar and front camera to the same spot up front.
  13. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hi Ray,
    I notice for the Gen 2 Prius, the install of the harness seems easier, connecting the Prolong harness to the battery side of the battery disconnect relay per step 18 in the below:
    2004 - 2009 Toyota Prius Plug-and-Play Car Harness Installation Instru – Hybrid Automotive
    I recently did the harness install for my Camry, and I had to open up the battery cover and connect the harness directly to the battery. This also seems to be how it would be for the 2010 Prius per the below:
    2010 - 2015 Toyota Prius (non plug-in) Plug-and-Play Car Harness Insta – Hybrid Automotive
    Is there a way to connect the harness to the battery side of the disconnect relay, just like for the Gen 2, without opening the traction battery cover? I am planning to install the harness for my 2010 Prius in the next few days.
    Thanks in advance.
    Raytheeagle likes this.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    When we installed my harness (I did this with @jeff652 ), we followed the instructions ;).
    Don’t forget once you have this connected there is 240 volts of dc running through the connections, so protecting it is a safety step if nothing else:).
    It only took under 2 hours to install and the harness is made with built in tie points to keep the harness in place;).
    I’d follow the directions (y).
  15. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Unfortunately, no. Toyota eliminated the nut/stud solution and went to snap in connectors. There is no practical way to tap into that style connector, which is why the connections must be done at the modules themselves.
