12v drain when hatch raised?
Discussion in 'Gen 3 Prius Technical Discussion' started by Caydoc, Aug 20, 2012.
  1. Caydoc
    Caydoc Junior Member
    32
    Savannah, GA
    Maybe this has been answered, but couldn't find it on search...is there some sort of battery drain when hatch is raised, even though the courtesy light has been manually turned off? Seems like I read something about this recently, and don't want to damage the 12v if it's true...
  2. PriusCamper
    PriusCamper Senior Member
    13,461
    5,431
    Pacific Northwest, USA
    You get the read light on the dash that says a door is open... Other than that their shouldn't be any other reason for additional power drain....
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The door lights go on. They are incandescent, which means they draw lots of power. There is no way to turn them off.
  4. PriusInParadise
    180
    91
    Hawaii
    The hatch latch switch is an input to the Main Body ECU, so at the very least, it wakes up the Main Body ECU, resulting in a draw even if the lights are not on.
    What I do when I need to leave the hatch open for an extended time is to flip the latch closed using a hook-shaped tool. This turns off the switch in the latch so the Body ECU thinks the hatch is closed.
    I also place a heavy folded up towel over the hatch latch in case I forget and slam the hatch closed.
    To actually close the hatch, I have to remember to release the hatch latch first.
    Montgomery and PriusCamper like this.
  5. PosauneGuy
    PosauneGuy Member
    124
    91
    California, here I come...
    2025 Prius
    I accidentally left my hatch open overnight once. When I saw it the next morning, I was certain that I'd drained the battery. Turns out the Prius will turn off the interior lights after a certain period of time, so as not to drain the 12v battery.
  6. gliderman
    gliderman Active Member
    751
    225
    Thanks!
  7. Matt M.
    Matt M. Member
    117
    San Francisco Bay Area
    Funny you should ask. I posted elsewhere about this, but... I was rear ended a couple of weeks ago. Drove the car home. Opened the hatch to look for damage, and then I couldn't close the hatch because of damage to the latch. I turned off both the dome light and the cargo area light, and figured the battery should be OK. 2 days later I wanted to drive the car to the auto shop and the 12V battery was dead. I was able to jump-start it easily, but I called a Toyota dealership to ask if the hatch being open could have drained the battery. As someone mentioned above, even if you turn off the interior lights, with a door or the hatch open the car's computer stays on, and it will drain the battery in ~2-3 days. Doesn't seem like a great design! But, it is what it is.
  8.
  9. IF, that is true, then remove, disconnect the car door bulbs. They are not needed anyway.
  10. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    FWIW ,I left my hatch up for 3 days [in the garage]......no problem.
  11. 2014
    2014 Member
    30
    31
    MA
    Rear hatch up for 2 days, interior lights switched off, no lights on inside that I could see and the 12V battery was too low to start the car. Had to jump start it.
  12. Mendel Leisk
    42,345
    Yup, any door/hatch open is going to be hard on the battery. Better have it assessed, say with an electronic load tester, and hook it up to a smart charger (3~4 amp range) for a full charging session, then see how it goes.
  13. 2014
    2014 Member
    30
    31
    MA
    Have it on a battery trickle/maintainer. After about 18 hours battery is at 12.3V. Will keep it on for the rest of today.
  14. Mendel Leisk
    42,345
    Really low amperage conventional charger? 18 hours and 12.3 volts doesn't sound good.
  15. 2014
    2014 Member
    30
    31
    MA
    Trickle charger/maintainer, at less than 4A.
    Ed Beaty and Mendel Leisk like this.
  16. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    I love my CTek (hat tip to Mendel Leisk...) ;)
    Raytheeagle and Mendel Leisk like this.
  17. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Another amazing tidbit, only found at...................Priuschat!
  18. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    True. Even with all interior lights off or disconnected, the drain is about 0.7A, so about 3 days will deplete even a healthy battery.
