12v duralast 8amu1r battery can fit prius
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 8, 2011.
  1. richard schumacher
    7,664
    1,043
    United States
    Please let us know how that works out.
  2. wildbottom
    wildbottom New Member
    99
    Did you get a Price Quote for the PVX-420T?
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
  4. Wingding
    Wingding Junior Member
    Montana/Michigan/Pennsylvania
    I was set to get a optima D51 today but I see in this thread the Werker 12v- 35ah {Werker SLAA12-35C.}
    It's for sale for $67.49 plus 16 shipping to me .. Thats apx. $84 vs $165 and Im not sure the shipping for the optima.
    My question is..... IS THE WELKER A ACCEPTABLE ALTERNATIVE?
    Thats a huge difference in price... There is no vent pipe though.....
  5. wildbottom
    99
    Model No. for vented battery is Werker SLAA12-35C. I couldn't find the vented one Online. If you could find a Batteries Plus nearby, call and ask. The vented one has grayish top.
    Werker is Batteries Plus's house brand. They are franchise owned. (Might be different from the Online store). So the franchise owner usually buys whatever they get cheapest and locally. I've heard some stores get batteries from Exide and East Penn(USA made). And Exide is not so good(maybe China). If you can, you should go and see for yourself to find a Quality battery. Plus it's $67.49 w/o shipping. (You'll need to RMA for Returns on Online purchases.)
    Oh yeah, remember to ask them to check the voltage on the battery before you buy since then don't maintain the charge for AGM batteries which they do for flooded ones. You shouldn't buy an AGM at full price if it's less than 12v. At least 12.5V is best. AGM loses 10% of charge per month on the shelf. It's recommended to charge them every 2-3 months.
    Check for Date of Manufacture. Probably shouldn't be month than 5-6 months. Quality AGM batteries should have Date info and provide MSDS papers. (You should be able to find the Manufacturer's Name on the MSDS as well.)
    The UB12350 batteries(33Ah) probably not a good choice if you have very cold winters. It has lower rating than the OEM with SKS(45Ah).
    UPDATE: Looks like the SLAA12-35C needs some sort of conversion.
  6. wildbottom
    99
    So are the JIS post for converting a bolt from a larger to a smaller diameter?
    What's the size of the battery ring terminals on the 2nd Gen Prius? Thanks.
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    2nd Gen Prius has JIS posts that look like regular SAE battery posts but are smaller in diameter. That is why you need a battery terminal kit if you want to install a Optima D51 (the Optima has SAE battery posts).
    The JIS posts that I linked to in an earlier post convert from M6 threaded sockets to JIS battery posts. It is essentially a brass JIS post with a M6 stud on the bottom to screw into the threaded socket.
  8. wildbottom
    99
    Looks like what I need. Thanks.
  9. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    skydive, It is 8 years old this year. Great battery! H
  10. Hal W
    Hal W New Member
    872
    53
    I will go with the Prius original when the time comes. Don't want to experiment with the Prius. I prefer to keep it original! H
  11. wildbottom
    99
    I called Concorde Office in West Covina, CA. It's $110 plus $25 shipping(UPS Grnd). It'll be $145 /w tax for me for Northern CA. Not bad for a battery that suppose to be better than the Optima. Add another $12 for Conversion Parts.
  12. dogfriend
    7,512
    1,189
    Carmichael, CA
    Sounds good, let us know how it works out. I will be replacing my 12V soon, possibly next month (it will be 4 years in service).
    Concorde looks like a high quality AGM battery. Another good AGM battery is the Odyssey, but they do not have a model with the right form factor & terminal configuration.
  13. wildbottom
    99
    More Update on the Werker Vented Battery. Case looks exactly like this linked. There are 2 left at the Store in San Francisco. Dated "E0", or May 2010. Doesn't say where it's made. It's does say it's from Ascent in Hartland, WI. and "Stationary Battery." These are use by UPS backup and Telecom. I'm guessing they mislabel it as WKA12-35C but it's actually WKHR12-33C since the case makes it fire retardant.
    Ascent is an subsidiary of Battery Plus. Werker is the brand name for Batteries Plus.
    One tested at 12.4V and the other 12.38V. Probably never been charged since they left the factory last May. Too bad they let them drop below 12.5V(when sulfation starts during self-discharge).
  14. wildbottom
    99
    I'm was doing some reading and it seems all AGM batteries last longer if they are charge no more than 13.4V(Float) and top off (14V) once in a while. I wonder if there's a way to add a smart charging system for the AGM battery in the Prius.
    Plus AGM batteries might require up to 30 cycles to get max capacity. I doubt the UPS companies do that for their batteries which usually go straight to float. I would cycle a new battery a couple of times with a smart charger before I install it in the Prius to help it get max capacity. Also helps to get the benchmark of a healthy battery w/o using an EIS spectroscope.
    These two measures should add a couple of years to the life of the battery especially on long trip and in hotter temperatures.
  15. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    wildbottom, I would be very grateful if you could post pictures! Also, did you get the JIS terminal kit from Concorde or Odyssey? As much as I love my Optima, having a replacement that doesn't involve hacking the positive terminal would be a huge benefit.
  16. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    I think the Prius charging system is already adapted for AGM batteries.
    See this thread for more info: http://priuschat.com/forums/gen-ii-...charging-12v-step-change-14-0-13-5-volts.html
  17. tf4624
    tf4624 Active Member
    527
    51
    Duralast=duraCRAP. Get optima battery
  18. wildbottom
    99
    Sounds like they do have a system and it's still somewhat a mystery to quite a few posters.
    One Post said "I'm pretty sure, when this 'feature' is working, that as long as the car is in drive and the cabin fan is off, the voltage stays low and if the rear window defroster is turned on, the voltage drops further to something like 13.2 volts." It happens to some people at around the 25th minute. But if you put it in Park or Neutral it goes back to 14V and the cycle starts over. I'll have to check it next time.
  19. wildbottom
    99
    Wonder if anyone tried the Optimate 4(.2A, .5A, .8A) Charger/Maintainer. Recommend for 2.5Ah-30Ah batteries(50Ah Maintainer). It's also has Charge Current regulation with temperature.Optimate 4 info
    TecMate also make the Optimate 5(up to 2.8A) and Optimate 6 (0.4A to 5A)for bigger batteries.
    Lowest price Charger/Maintainer/Desulphator is CTEK US 800 (.8A)with High Temp. Reg [$33 at Amazon]
    Another choice is the BatteryMinder line.
    Model 12117(1.3Amp) without Temp. Regulation
    and Model 12248(2,4,8 Amp) with Temp. Regulation
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Thanks! A quick look at the site made me worry a bit:
