12V Electrical System Amp Output?
Discussion in 'Gen 2 Prius Technical Discussion' started by Angelo, Oct 21, 2016.
  1. Angelo
    Angelo Junior Member
    16
    Hey guys, I have a question that I hope can be answered by the pros here. I've already provided my VIN to the Dealer for a Spec sheet, asked a couple of audio gurus, and nobody was able to provide me an answer.
    I am an audiophile and I have a custom audio setup in the car now. Alpine Head unit, Component Speakers, Subs, Two amplifiers and so on.
    What I want to know is what output the 12v electrical system can handle. How many amps can it sustain so I know it is charging the battery sufficiently during operation. I haven't had any problems yet, but If I add more equipment I would like to know that math so I can comfortably know what I can and can NOT do in the car.
    Thanks everyone.
    Angelo
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    It’s 80…100A (depending on who you ask) minus whatever Prius itself is using. But voltage might drop before you get that out of it. Of course 12V battery will provide the extra for peak power. You should but good 12V battery in it.
  3. Angelo
    16
    I just got a brand new Toyota 12v battery put in. Is there any way to boost the amp output and add another battery? I know the Prius has no standard alternator like in an SUV, is there anything that can be done?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1000 watts is doable.
    More involves owning another car.
    Always be in Ready.
  5. Angelo
    16
    Yeah I got a bass amp that runs 1100 watts, and a 4 channel for mids n highs at 250w to the channels. So Im probably not getting full output with all the other car electrics on.
  6. valde3
    2,002
    750
    Finland
    Not really.
    Unless you want to add your own DC-DC converter. You can probably take something like 6A out of hybrid battery without causing a problem so you could add your own 200…250V DC to 14.4V DC converter with output current limited to about 80A. Or more (maybe even or double quadruple) depending what is the actual limit of how much power you can take from hybrid battery without causing fault code. Probably would be better to keep the other 12V system separated from the factory 12V system.
    #6 valde3, Oct 21, 2016
  7. Mozencrath
    Mozencrath Junior Member
    50
    First of all, adding 10 batteries or 100 will not make a difference. The 12V system is powered by a DC/DC converter within the Prius. The 12v battery provides no power to your 12v components, even if you are pulling the full 100Amps allowed by the DC-DC converter. That being said, adding a capacitor would be beneficial.
    Even if you had 3,000w worth of amps, I would not foresee you having any issues blowing the 100A dc/dc fuse. Even if you were to pull all 3,000w from those amps, you are talking about possibly a few miliseconds. Even if you have your volume maxed out and subs pumping, you are not drawing 3,000w through the whole song, only at the peaks of and only a few miliseconds at a time. You would need to try really really hard to blow a 100Amp fuse with any amount of amplifiers and speakers. Add a 2 farad capacitor and if you DO somehow come near the limits of the DC/DC, the capacitor might help the voltage from dropping.
    What you are thinking is that a Prius uses an alternator. In cars that have alternators, lets say it has a 100A alternator and you are drawing 90amps from it...The voltage is going to drop near the battery voltage at which point the battery will actually be supplying the power to your amps. In the Prius, the DC/DC converter voltage will not faulter at 100 amps thus the battery will never power your system.
  8. ChapmanF
    19,033
    Some PriusChat members (at least Bob Wilson if I recall, and possibly also hobbit) did the obvious tests several years back, and found that the Prius DC/DC converter output voltage does indeed fall off near full output, which was around 100 amps. It would be odd if it didn't; they sized the thing to cover the expected loads.
    It also has a "help! draw less current!" output that it asserts (on a circuit labeled IDH) when it is close to its output voltage falling off. The HVAC computer watches that signal and sheds the electric heat if necessary. I don't think anything else in the car from the factory pays attention to it, but I might, if I were adding a heavy load.
    -Chap
