12V Lithium
Discussion in 'Gen 2 Prius Main Forum' started by artc, Oct 30, 2020.
Tags:
  1. artc
    artc Junior Member
    US
    Anyone feeling the winter crazy's and in need of a 12v, Battery Hookup has an "interesting" possible replacement.
    LithiumPower 12.8v 32ah 410wh LifePo4 Module w/ BMS – Battery Hookup
    Should work,especially if the BMS is as good as they claim. 32A (1C) discharge should be enough - as long as there's a little wiggle room - worst case it would need a capacitor for the very short transients at startup. Of course, it might not work, or it may not fit or...
    If we could reliably demonstrate that this style of lithium is a good replacement for the expensive and fairly low capacity lead acid we could potentially save some money and have a better battery for our cars. But that's not where we are, so if you go this route it's very much experimental.
    I'd buy one, but I've just (last week) replaced with a very similar, but new-and-much-more-of-a-pain-to-install (tiny terminals) 30ah lithium (40A discharge, designed for solar storage, a little more expensive). Not enough miles or time yet to know how it's going to work out...
    SFO likes this.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Looks interesting but I have a question. It lists the maximum charging current as 32Amps. What happens if the battery is partially discharged and you ready up the car? The Prius DC-DC converter is voltage regulated, with no current limiting to the 12V battery. Will the BMS "disconnect" the cells if they accept more than 32A?
    I don't know enough about lithium battery tech to have an answer but I would want one before I considered this.
    donbright likes this.
    52,831
    @jzchen has replaced with lithium
    Data Daedalus and artc like this.
  4. artc
    artc Junior Member
    US
    I don't know the answer to this. The limit is likely the BMS not the cells - those should be able to take higher charging currents. Discharging, I would expect the BMS to drop out if you pull too much current (it does on smaller BMS systems) but I don't know the behavior when charging.
    I'm surprised the the DC-DC doesn't have any regulation to the battery charging system. It's not advisable to charge lead acid at much more than 1C and the recommended rate is usually somewhere less then 0.5C.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Yes I did, thanks for helping me share. But mine was $$$ in comparison, as it's specs are similar to the original, plus has backup cell, (which I haven't tried/used yet). I do hope by now they've gotten rid of the foot hold down lip so they fit nicely in place. (I was promised they'd make a change in the next batch).
    moto g(7) power ?
    artc, bisco and Data Daedalus like this.
  6. artc
    artc Junior Member
    US
    Replacing with a true "starter" battery will be much more expensive, although should work without issue. The BMS for a starter has to provide 400A+ to start a car. I would expect the low-cost, low amp lithium to be a suitable replacement in the Prius. The cost has recently come down enough for me to feel it's worth testing.
    The Lithium battery was much smaller. The issue with fit was to raise it up enough for the connections to reach. It also has tiny terminals so I had to shim the connectors to get them tight.
    I did think of using something similar in a minivan with the idea of bypassing the BMS with a high-amp contactor when the starter is engaged. Considerable effort to wire and without some cleverness you could still over-discharge the lithium while starting - the work didn't seem worthwhile. My motivation in that case was that, with all the work-from-home, that van has driven almost no miles and the battery has discharged and destroyed itself (I bought another LA and a battery disconnect).
    tangerino and jzchen like this.
  7. mr_guy_mann
    4,113
    2,011
    NJ-USA
    I had a gen2 at the shop with a flat 12V (that measured around 5.0V). I put a booster pack on it to drive it inside where I wanted to check function of the electrical system before using a charger on it. My small amp clamp pegged at 40A so I got my Pico high current clamp and scoped it. Right after going "ready" I measured 80A going to the 12V with the booster attached- dropping shortly to 70A. I removed the booster and it still was supplying 60A to the AGM (a Napa 46Ah made by East Penn manufacturing).
    I'll assume that the rate would have dropped fairly quickly as the battery accepted charge but I shut it down and put my external charger on it at 10A (opinions vary as to whether AGM should be at 0.2C or 0.4C). 1.3C charge rate is a lot :eek:
  8. artc
    artc Junior Member
    US
    The lithium has been in the car for a little over a year now. The car doesn't get driven much - part of the motivation was to get a battery that would cut out before a damaging over-discharge.
    So far I have not noticed any appreciable difference from the Pb. I don't track it that closely, but the MPG seems to have increased slightly, but that could be confirmation bias or just a result of putting any good 12V in the car.
    Battery Hookup has these batteries in new condition, but somehow only in pairs...
    https://batteryhookup.com/products/new-2-pack-li-age-12-8v-32ah-410wh-lifepo4-w-bms?variant=41203476594850
    32A should be enough, but see the comments above and reach your own conclusion.
    tangerino likes this.
  9. artc
    artc Junior Member
    US
    Two year update. Still going fine. One time the car was left for long enough that the BMS kicked out and saved the battery. You then need to apply 12V to get the car rolling and charging again, but the battery is find (unlike lead acid which, without a BMS, would discharge to zero) That was only once and the car routinely sits for a month or so without a problem.
    Haven't noticed any real difference in the car and have mostly forgotten that it has this odd little lithium rather than the recommended lead acid.
    jzchen likes this.
  10. artc
    artc Junior Member
    US
    Battery in the second Prius (2006) died. I replaced with a different brand of LiFePO4 12V 36Ah - Pionergy - $130 . Very shortly after installing, the combo-meter went out - the standard problem needing the capacitor replacement. Possibly related to the battery change and so a higher voltage, but probably didn't matter whether Lead Acid or Lithium.
    The biggest challenge in using these batteries is the tiny terminal sizes on the lithium batteries. For this conversion I created a battery "post" for the positive side using a 3/8th copper pipe cap. Drill a hole in the bottom for the terminal screw, clamp the terminal clamp around the copper cap - it's about the right size - screw into the battery through the hole in the bottom. The negative clamp is smaller and this time I just screwed the clamp directly to the battery terminal (seems to make good contact).
  11. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Don’t worry I do not think it’s the higher voltage. My logic being the charging system spec is 13.0 V to 15.0 V. 15.0 V is higher than a LiFePO4 for sure. Mine have a built in Voltmeter and upon arrival pre installation they ask you to check. I recall 13.x V….
    I have 4 of the pink eBay LiFePO4 batteries (for automotive) now. 3 are installed and one sitting inside our home. I did not install it because the battery in that vehicle is attached to a maintainer and it’s not healthy to keep them fully charged.
    I know projectlithium had/has one on the website for the Prius at a much more reasonable price. (It is listed as a prototype)…
  12. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Your logic is flawed. The problem occurs when the combination meter starts up. Because of the higher voltage that comes with the new 12 V battery, the combination more frequently fails to start. Once the car is READY and the DC/DC converter is supplying 13.2–14.4 V there is no issue.
  13. artc
    artc Junior Member
    US
    Well, 2025 and the original Lithium is still doing well. When I do replace it, I'll probably use something with a little more capacity. I could get double the capacity today for the price I paid in 2020. I've heard that the cars are smart enough to disable non-essential systems (SKS??) when the aux battery voltage drops, but that gentle drop doesn't really happen with lithium so I've had to "jump" the car a couple of times after leaving it unused for a few weeks. The BMS protects the lithium battery from over-discharging, so it's an inconvenience rather than anything that will degrade the battery. A LA aux battery without a BMS would be damaged by repeated deep-discharge.
  14. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    When I was having constant problems with my existing 12V battery, I acquired a 100Ah lithium replacement, which was easily 3 times more capacity than the OEM. But there are additional wires connected to the OEM battery, so I opted to put the lithium battery in parallel with the original instead. I separated it with a "smart isolator" which cuts out at 13.2 volts of charge. I also installed a 40A toggle switch to bypass the isolator to boost if necessary. It's been over a year since I installed it, and no troubles at all.
  15. pasadena_commut
    pasadena_commut Senior Member
    3,052
    951
    Southern California
    Placing batteries of different chemistries in parallel seems like it could go badly wrong. They don't charge up the same way, they don't discharge the same way. Minimally both batteries need to be at the same voltage, or very near it, when they are connected. Perhaps the "smart isolator" can ameliorate the risks. A battery management system is a safer way to go.
    Having batteries with the same chemistry in parallel can cause some trauma too if one of them fails. For instance, two 6 cell lead acid car batteries in parallel is done sometimes, especially on big trucks, but if a cell shorts on one of the batteries a very large amount of current is going to flow from the 6 cell to (now) 5 cell battery, I would think enough to damage the good battery too in a relatively brief period of time. Parallel AA, AAA, and other small alkaline cells are less hazardous as they don't produce that much current. ~1A at ~1.5V is ~1.5W, which is about the power of an incandescent bulb night light, whereas ~200A at ~2V (one shorted cell) is ~240W, which in a small volume is going to be very hot, very quickly.
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    They don't work in parallel. The lithium battery is protected by a maintainer, called a "smart isolator." It allows the battery to charge, and then it's isolated. The OEM lead-acid 12V battery functions normally by itself. The auxiliary battery is not connected to the system, until I activate the bypass switch, which has never happened, but if it ever does, it's no different from getting a boost from a lithium booster pack.
    Please worry about something else.
  17. pasadena_commut
    3,052
    951
    Southern California
    That is not "in parallel" with the conventional meaning of that phrase.
  18. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Your phone has a lithium battery. While it's charging, it's in parallel with your car battery.
  19. pasadena_commut
    3,052
    951
    Southern California
    Actually, it isn't. There are other components in that circuit which control the current into the lithium battery. Minimally something like a FET to manage the amount of current, which is placed between the positive of the car battery and the positive of the lithium ion battery. Or it could be on the ground side, doesn't really matter which side is switched. There is likely to be a diode too, to prevent a disaster if it was somehow plugged in with reverse polarity. That would come really close to being in parallel when the FET is fully conducting and if there are not any other components in that loop, it would differ only from the small voltage drop across those one or two components, plus whatever resistance they might still provide.
    Electrical nomenclature doesn't seem to have a good term for this. Sometimes it is called complex, sometimes "serial-parallel". Serial is serial, parallel is parallel, and anything else, which is most circuits, is usually just not called out as being "not serial or parallel".
  20. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I understand that you are defending your original point, that a lithium battery in parallel with the OEM lead-acid battery is risky in some way. It really isn't. The system maintains a charge on the lithium auxiliary battery and then disconnects, That's it.
