12V low power system in a Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by patcoghm, Jan 24, 2022.
  1. patcoghm
    patcoghm Junior Member
    57
    Watch this Weber State College Video that explains the 12v auxillary battery and how to charging it.
    ForestBeekeeper likes this.
  2. patcoghm
    57
    This is the current model they used for charging the 12v AGM battery found in the Prius.
    Snap-on Store
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    No - it's a Gen 3 - the Gen 4 doesn't use an AGM 12 volt. You can see at the start of the video it's a Gen 3 - and he says it's an old 2010.
    There might be some general similarities - but the Gen 4 is a very different vehicle.
    Hopefully the Moderators move the thread to Gen 3.
  4. patcoghm
    57
    Then check this on how to start the Prius with a Dead Battery.
  5. alanclarkeau
    7,044
    7,584
    Again - beware - this isn't a Gen 4.
  6. patcoghm
    57
    Your right this post was about a 2020 prius prime and its constant dead batteries. Sorry and I would move it if I knew how. Yes it was a Gen 3 the video and maybe i'm wrong but the Prius prime charges the 12v the same way, when in Ready, thru the DC - DC converter. If its differnt im unaware of that. But its a great explanation on the 12v system.
  7. alanclarkeau
    7,044
    7,584
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    It's just as well that the video shows a Gen 3 since this is in a Gen 3 forum.
    This is the Prius Prime charging system, which is the same as the regular Gen 4.
    Pretty much all hybrids charge their 12V batteries in a similar fashion but there may be slight detail differences.
    I don't get this talk about Prius Primes and frequent dead batteries. I've never had one in my 2017 and it's still the original.
    Edit to add: LOL! @alanclarkeau, I just followed your link after posing this. Guess I could have saved myself some time if I'd done that first. :rolleyes::D
    alanclarkeau likes this.
  9. alanclarkeau
    7,044
    7,584
    It was originally put on Gen 4 FORUM - but I requested that it all move to Gen 3 seeing that's where it belonged.
