12V outlet - Maximum power
Discussion in 'Gen 4 Prius Main Forum' started by hybrid hugger, Feb 13, 2017.
  1. hybrid hugger
    hybrid hugger Junior Member
    27
    2016 Prius Four
    I have been using this Anker car adapter
    in the center console 12V to charge my iPhone 6s and 5s for several weeks.
    Yesterday the outlet stopped working, the rear outlet still works.
    The Toyota dealer is looking at it but he said that I shouldn't plug in 2 phones at the same time.
    The adapter draws just 4.8A and the outlet is rated at 15A so I don't see what the issue is. Moreover he said that the charging cable I use determines the amount of charge drawn not the adapter. I am scratching my head. I understand that a poor cable may not be able to carry the current but isn't the *maximum* current drawn from the outlet determined by the adapter plugged into it?
    Thoughts? Thanks
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The phone determines the maximum current drawn unless the USB port advertises a lower current.
    An iPhone 5s will use a maximum of about 1A, the 6s about 1.6A.
    So the total consumption would be about 2.6A @5V for 13W total. Taking into account the inefficiency of the 12 to 5V conversion this would be about 15W at 12V or 1.25A from the outlet. That should be no problem for the outlet.
    Are you sure the adapter is plugged in fully, I've had a couple of adapters that make unreliable contact, the outlet was not really designed as a 12V outlet!
    Have you checked the fuse for the outlet, has it blown or fatigued?
    kevin
    RCO likes this.
  3. hybrid hugger
    27
    Yes the 15A fuse had popped, replaced it, works fine now.
    Still not sure what caused the fuse to pop since the adapter wouldn't draw more than the outlet could supply. It seems to be plugged in firmly.
    Any ideas?
  4. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    I recently had a bad adaptor with an internal short or something that would blow the fuse immediately. Tossed it in the trash.
    Overnight Prius Addict
    2009 Prius 4 Black
    2012 Prius 4 Blizzard Pearl
    2013 Prius 4 Black
    RCO likes this.
  5. hybrid hugger
    27
    Hmm but in my case I have been using the same adapter for many weeks without any issue. After the fuse was replaced it is working fine again. I guess there may have been some stray metal or something in the receptacle that caused a short, will clean it out.
    Thanks
    Bluegrassman likes this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Look at the cable on the chargers for damage - crimping, shorts. If it happens again, I'd try a different adaptor, I've had quite a few go bad, they're usually very cheaply made.
    Bluegrassman and RCO like this.
  7. hybrid hugger
    27
    True but Anker products in my experience are very well made. And I am using MFi certified Lightning cables with no visible damage.
    Thanks for the discussion and advice.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Agreed. Anker makes good products but no production line is perfect. 1 out of the 3 Anker lightning cables I bought no longer works. It's a little over a year old. There's no visible tears or damage either.
    What you describe sounds like a faulty 12v USB adapter. If the fuse trips again, you'll know.
  9. hybrid hugger
    27
    Sigh...I hope Apple hurries up already and adds Qi-compatible wireless charging so I can just place the darn thing on the gorgeous charging pad the Prius has and toss all these cables and adapters.
  10. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    I use splitting cable and two Anker chargers and 4 hungry device at same time.....no issues......read advice..posted by other members
    RCO likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Throw your Applecore away! Get yourself a good android phone. 1) they're usually cheaper to buy and 2) the system is slicker. They often offer expandable memory and occasionally room for a second SIM card. Unless you go for Galaxy note 7, you should be fine with a Sammy (they have Qi charging inbuilt) and so does my Nexus.
    priuscatprimeguy likes this.
  12. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    I don't use the 12V outlet at all. I was going to get a vacum that was powered by the 12V until I read a post somewhere where they said it messed up the electrical system of the car. I don't even want to risk that. So I just purchased a portable battery pack. And I will carry that with me on road trips and camping and power outages. It charges my iPhone 6 Plus faster than the apple wall charger. I did a video review of it on youtube but I don't think it is appropriate to put a link here since it isn't a Prius review. But my channel there is Wonderful Wandering Topics if you want to see it.
    RCO likes this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    According to the manual, the 12v Power outlets are rated at 10A max
    RCO and priuscatprimeguy like this.
  14. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I am hoping I can still use my Black and Decker vacuum cleaner when I get my car. I use it currently in my Zoe without problem, so fingers crossed :unsure:
    RCO likes this.
  15. alanclarkeau
    7,045
    7,593
    I wouldn't be concerned as long as it is within the 10A rating - which my old car vacuum would have been. Just check the rating first.
    RCO likes this.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    No good for the supplementary 12v 150w electric heater we have, that SWMBO used to use in her old Mini Metro some years back to defrost the windscreen. I do miss the quickclear electric heated windscreen on the Mondeo.
    RCO likes this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I've always been jealous of that heated windscreen, even when they were reported as dangerous in fog because your eyes could focus on the heater elements in reduced visibility. Nowadays they're much finer and not easily seen.
    kithmo likes this.
  18. Prodigyplace
    12,712
    11,848
    Central Virginia
    I thought they were in the UK
    See Apple Corps
    RCO likes this.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    They reckon they're stayin after Brexit, too!
