12V receptacle doesn't work...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dino33ca, Apr 21, 2013.
  1. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Is that a common problem on Prii? I couldn't find any threads about this. Is there a fuse that can be replaced or does one have to replace it?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Nope. Not common. I would check the fuse.
    I blew the cigarette lighter fuse in my Prius (I think, possibly my former Z) by using a crappy 12 volt splitter. I tried it again and it blew it again. Too bad I think it was too late to return it. My other splitters were/are fine and I've never blown the fuse again.
    Dino33ca likes this.
  3. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Thanks, that's exactly what I did as well. It seemed to work at first because the gps hooked up to it worked. I thought maybe it was running on the battery, but now that you mention it, it probably blew just after I hooked up the three in one splitter. The fuse must be in the front fuse box under the hood? I looked in there and couldn't see one, but maybe it's labeled under a different name or abbreviation. I'll look again....
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    They are inside, in the driver side junction block. Two labeled "Power Receptacle" @ 7.5A.
