12V surprise
Discussion in 'Prime Main Forum (2017-2022)' started by IABoy987, Apr 11, 2023.
Tags:
  1. Trollbait
    12,824
    Sounds like the ECU settings were lost, and the car needed to relearn the best settings for fuel, climate, and driving style.
  2. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    apparently OEM 12v battery lasting 5+ yrs. Car bought in 2019 Sept. Just had it checked 5yrs/3 mo later, still has 82%. just hope it just doesn't suddenly collapse.
  3. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    The danger of having an exposed positive and negative connection near your battery terminals would make this a high risk proposition. Also, there could be a danger of arcing when connecting the jumpered connectors up to the new batteries.
    Having had to replace the display unit in my 2018 Prime, I am EXTREMELY careful with anything to do with the battery. FYI - if you reverse the leads on your battery charger or cables, one of the very first things to blow out is probably going to be the display unit. According to Toyota, there are fuses inside the display unit that are replaceable but I wouldn't count on it. My issue was my head unit just died for no apparent reason. Toyota quoted me $9k (!!!!) for a replacement display unit and about $1k in labor. Luckily I found an independent Toyota Master Mechanic who swapped in a used unit that cost me about $1200 and about $500 for labor.
    Dael likes this.
  4. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    Any prelim. probs with head before failure?
  5. frederw1701
    frederw1701 Junior Member
    53
    16
    WA
    2018 Prius Prime
    I'd like to ask whether one particular option works on a Prime. First let's get the others out of the way.
    Option 1: don't let the 12V battery discharge in the first place.
    PRO: improves battery life, doesn't cost anything, and is widely considered easy to do.
    CON: it would be easier to do if I lived alone.
    Option 2: Keep a jump start pack in the glove box
    PRO: You can jump other people's cars.
    CON: By the time you use it, the 12V will already have been damaged by the deep discharge.
    Option 3, the one I'm wondering about: install a "priority start"/"battery protector" unit.
    These normally are transparent but when a 12V gets too low they disconnect it to prevent further discharge. Then when you get out to the car and realize the situation, you can push a button to reconnect the 12V while you start the car.
    PRO: saves battery life and prevents problems.
    CON: You have to reset everything, and I have no clue whether they work in a Prime. Is that override switch going to be compatible with the zoo of electronics under the hood? At least there seems to be room to install one, unlike my other Prius, a Gen 2 with the tight trunk compartment.
    Has anyone installed one and been happy? If so what brand?
  6. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    Option 4: Get a Battery Tender installed to keep a trickle charge on the 12 volt. You have to keep it plugged in all the time, so if it's not convenient to an outlet, it won't work for you But otherwise it is a simple, trouble free solution.
  7. Mendel Leisk
    42,343
    That’s my approach. I replace the stock battery in September of 2015, with an Optima YellowTop (not the best option in hindsight, but working fine).
    The car is garage parked, currently seeing about 3k kms use per year, and invariably on a charger, using a quick-connect for convenience. Still testing well, CCA well above spec, and at-rest voltage 12.8~12.9.
  8. Trollbait
    12,824
    Thought that was a pert of option 1. Keeping it plugged in falls under the con.
  9. frederw1701
    53
    16
    WA
    2018 Prius Prime
    With the most recent flat battery (the Gen2), it was connected to a Battery Tender. The Battery Tender could have handled the regular turned-off current draw but with an interior light left on for three weeks, it could not keep up.
    Well, then, Option 1A, a higher capacity Battery Tender.
    Is there even a way to install undervoltage protection in a Gen2? That's one cramped battery compartment. Would it work if so?
    Starting to wonder if we should just lend the cars to neighbors when we're on long trips and let the car handle maintaining the charge.
  10. Trollbait
    12,824
    It invokes the option 3 con, but simply disconnecting the battery is an option when away for long. Can even keep the battery on the minder.
  11. frederw1701
    53
    16
    WA
    2018 Prius Prime
    Reasonable option. Con, it's a fair amount of work to get all our junk out of the trunk, find a place to put it, and get to the battery to disconnect/reconnect it.
    For a little extra work, I could turn off the smart key system for the duration of the vacation. That would reduce current draw.
  12. BIDTOYO
    BIDTOYO Junior Member
    29
    Boise
    2025 Prius
    IMG_1587.jpeg With a 2026 Prius LTD, when the 12v battery dies, can I use a cable connection between a 12v power source the odbII port to “start” the car and drive?
  13. ChapmanF
    19,019
    Doubtful. Pin 16 of the OBD-II port is connected to +12 through a fuse. The fuse rating is large enough for memory-saver devices to work, supplying enough current to prevent settings in ECU memory being lost.
    I don't know what that fuse rating is in a Prime, but in a gen 3 liftback it's 7.5 amps. Probably hasn't changed much. I don't think that will pass the amount of current that would be needed to push the power button and start up the car.
    Now if you had a device there to supply a current limited to 5 amps or so for some hours, bringing the battery back up, and then try starting the car, you might have decent luck that way.
    BiomedO1 likes this.
  14. BiomedO1
    BiomedO1 Senior Member
    4,592
    2,409
    Left Coast
    :p:D Ya; beat me to that one.
    Depending on how low the battery is and how much more power is need to close those traction battery relays - There's a very good chance you'll pop the fuse on that circuit.
    It's a simple matter of just finding the jump point under the hood.....
    I believe that's the simplest approach when swapping out the aux. battery. Also use a 6 inch pool noodle to cover the positive cable battery clamp - to prevent accidental shorting to ground. This also works great for wiper blade replacements - to keep the arm from damaging your windscreen.
    #34 BiomedO1, Sep 26, 2025
  15. Mendel Leisk
    42,343
    The Solar Memory Saver is designed for the use its namesake infers, not jumpstarting.
  16. ChapmanF
    19,019
    It might be that we talk a little too much about the power needed "to close those traction battery relays". Yes, those do need to close, as a late step in going READY, but in the grand scheme of the power needed to do that, well, going READY starts out the same as IG ON, with power to all the car equipment that gets power in IG ON. That includes a couple dozen computers, the instrument panel, some pumps, and so on, also extra things like the wipers or seat heaters* if they were left on when the car was shut off.
    As soon as the HV control ECU has completed its checklist and decided it's ok to close the battery relays, the DC/DC converter comes online and takes over supporting those loads, but all of them were drawing from the 12-volt battery for the second or so before that happens.
    The battery relays aren't an especially significant part of that load, just another small part of the total.
    * bisco tells me the seat heaters might be auto-off in some generations/trims
  17. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Wow, had not realized how this thread grew! I only get like maybe one or two notifications, then nothing, so assume the thread died.
  18. BiomedO1
    4,592
    2,409
    Left Coast
    :D:LOL::ROFLMAO::p Your obviously not a fan of zombie movies/shows.:ROFLMAO::whistle::cool:
  19. BIDTOYO
    29
    Boise
    2025 Prius
    ChampmanF....
    Thank you for the background technical explanation regarding my original question. Is your answer to my question Yes or a No?
  20. ChapmanF
    19,019
    Re-reading the start of my post, it looks like my answer was "Doubtful."
    So the answer to your follow-up question would have to be, um, "No."
