12v tire inflator
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Scott_R, Nov 7, 2018.
  1. Scott_R
    Scott_R Member
    441
    23
    Long Island
    2024 Prius Prime
    I'm looking for a 12v tire inflator that’ll operate off the 12v outlet.
    This has been getting good reviews from various sources. Keeping in mind the outlet’s 120w limit, the specs describe the product as:
    Min. Amp: 10 Amps
    Maximum Amp: 15 Amps
    which has me baffled as to whether it’ll cause problems. If I remember correctly my car (a 2012 Prius IV) has a 15amp fuse for the 12v outlets.
    I’m not looking to do a direct hookup to the battery, so thought this might be an option.
    Any thoughts?
  2. Mendel Leisk
    42,019
    Would a inflator that runs on regular AC 110 volt not work, not practical? Just curious.
  3. Scott_R
    Scott_R Member
    441
    23
    Long Island
    2024 Prius Prime
    I want something I can keep in the car to use away from home, so it needs to be powered by the car. I’ve looked at cordless inflators but I don’t want to find that the inflator’s battery is dead when I need it.
    #3 Scott_R, Nov 7, 2018
    Jeff68005 and Mendel Leisk like this.
  4. padroo
    padroo Senior Member
    2,763
    2,252
    You can actually inflate a tire with a hand pump.
    How many people have never used a hand pump to inflate a tire?
  5. Scott_R
    Scott_R Member
    441
    23
    Long Island
    2024 Prius Prime
    Yes, I know, but this is more compact than a hand floor pump—none of the several types I have fit in the area above the spare tire. This pump has a similar size as the Sears dc pump I have (9.8amp) that fits in there but, for some reason, has twice damaged tire valves stems.
  6. padroo
    2,763
    2,252
    You could tap the 12V battery with a short cable and a plug fuse protected that would be easy to get to.
    Just an Idea.
    RC models have some small high current plugs that would more than do the job.
  7. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
  8. RoadNoise
    RoadNoise Active Member
    136
    187
    Huntsville, AL
    Two Eco
    I just bought this one a few days ago after my pancake compressor sprung a leak. Tried it out yesterday and works like a champ.
    12V 100 PSI High Volume Air Compressor
    With a 20% off Harbor Freight ad coupon it's about the same price as the Costco unit (although the Bon-Aire unit is probably fine, too). I recommend this metal one as opposed to the Pittsburgh yellow plastic version, which is cheaper in cost and construction.
  9. Mendel Leisk
    42,019
    Vlair is a respected name; happened to notice this in a local (KMS Tools) flier:
    (Canadian dollar prices, likely better deals in the States.)
  10. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    You are way over thinking it. Just get a cheap small inflater from Walmart or something and go on with life. The use case for these things is by definition infrequent, so longevity is not an issue. I've been riding my motorcycle with a cheap "slime" brand for 14 years and have used it a few times in that time period. I am certain it has plenty of life left in it.
    Same for cars. Cheapo one in the trunk of every car I have. They work well enough for the use case. At home I have a compressor with a tire inflater attacment.
    Starship16 and jerrymildred like this.
  11. Mendel Leisk
    42,019
    Yesterday I aired up snow tires I'd installed the day before. Having sat for about 8 months, they were all around 34 psi, and I opted to bring them all up to 40. Using a hand-powered bicycle pump, it took 40~50 strokes for each, and maybe 20 minutes in total, including checking pressures after pumping, bleeding out a bit of air when I overshot.
    The pump I got is a cheapy Schwinn, and I'm really not impressed with it, in particular pushing on the air connector is awkward. I do have this in an amazon wish list...
  12. Randall Gradle
    Randall Gradle Junior Member
    Dallas, TX
    Four Touring
    I use a Ryobi tire inflator. It uses the 18V battery that my tool set uses so it's s cinch swapping batteries out and they have charge level indicators. I tried several cheap models but tired of them breaking down when needed.
  13. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    Bicycle tire, yes.
    Car? Not me-have fun with that.
    Starship16 likes this.
  14. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Think outside the box.
    I bought an inverter with a 110 outlet, plugged it in the rear 12v (Prius v), connected that with a 2 ft orange heavy duty extension cord to the battery booster/compressor I use.
    Once per month, I plug it in while I drive around to maintain charge, unplug after.
    If you don't have a 12v in the rear, you could plug the inverter in the front and run the cord to the back or even put the booster in the front floor. Its only for 1 day anyway.
  15. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    If you get one get a compressor/booster/light combo. Mine even has 2 usb ports lol.
  16. Leadfoot J. McCoalroller
    8,162
    7,665
    Pennsylvania
    2018 Prius c
    I have the harbor freight compressor listed above. They have clearly gone up against fragile fuses before.
    The kit comes with these instructions, which neatly solve the problem and also apply to every other portable compressor:
    "Start the unit before connecting the air hose to the tire valve."
    By starting the compressor motor in advance, the electrical surge load is cut considerably- it doesn't have to push against already-compressed air in the tire. I've never burned a fuse with it.
    It's a fine solution. I got it 4-5 years ago, one of their tent sales for around $20. It's the only compressor I've got, and it has been enough.
    Salamander_King likes this.
  17. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Make sure your 2012 Prius IV has 15 amp fuse on the 12v outlets. I had 2015 Gen3, but its 12v outlets were on 10 amp fuse. I have Viair 70P 70P Portable Compressor | VIAIR which has Max. Amp/Watt Draw: 15A/180W spec, and it blew fuse every time I plugged into the car's 12v outlet. I ended up getting a battery connecter alligator clip extension cord to directly wire from the 12v battery. It won't be fun to find out blown fuse with flat tire late at night on a road.
    #17 Salamander_King, Nov 9, 2018
  18. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    I tried the bike pump thing. SHEESH! I'm no wimpy dude, but after 30 or 40 pushes on that handle, I was pooped! Three more tires to go... :ROFLMAO:
    In another thread, they said to make sure and put the car in Ready Mode before plugging in the air pump to the cigarette lighter socket. And is the cord long enough to reach the back tires? I assume it is. But wait, I don't want any blown fuses! What's up with that???
    Paranormal Rob likes this.
  19. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Mine is similar to the picture. I got it at Walmart a couple years ago when I had an SUV and needed something bigger. Now it sits in the back of the Prius, strapped down with a bungee cord.
    I do Uber/Lyft part time so I wanted something that could do everything quick. Screenshot_20181109-073804_Chrome.jpeg
  20. Scribe
    Scribe Junior Member
    45
    DeLand FL
    2013 Prius v wagon
    I bought the harbor freight inflator but had to change out the fuse to 15amp since all my accessory circuits are 10amp, their 10amp rated pump draws more juice so it my still let you down. Had good experience with Campbell Hasefield inflator 12 v inflator but it died after 15 years.
    LG-LS777 using PriusChat mobile app
