12v Yellowtop Installation Success!
Discussion in 'Gen 2 Prius Main Forum' started by GuamKelly, Oct 8, 2010.
  1. Patrick Wong
    18,210
    6,526
    However, if you are replacing the 12V battery because your Prius is exhibiting weird electrical behavior, then you will want to let the ECUs power down, and not use a second power source to maintain voltage on the 12V bus.
  2. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    GuamKelly, When you put the new 12 volt in your car did you experience a "new car" smell coming through the rear vent? Ryan
  3. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Not that I recall, Ryan.
    My newly installed Wet Okoles make it smell a bit like a Dive Shop, though (a not unpleasant association!).
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I agree that the charging rate necessary to keep the soc healthy is insufficient, especially coupled with peoples penchants for adding sound systems and leaving door ajar or just listening to the radio in acc mode while waiting for the spouse or kids. My battery is six years old now and getting minimally more healthy since I disconnected all unnecessary lights, ie: doors, trunk. I never use the interior light as it is not too bright anyway. I think the most sensible, economical solution is to just buy the largest Ah that physically fits and modify the post. Probably a motorcycle or lawn mower battery would work fine for 40-50 bucks.
