12Volt Battery issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rcmansid, Jun 16, 2012.
  1. Rcmansid
    Rcmansid New Member
    An issue is the original 12 Volt Battery, because the terminals on the factory battery are skinny, they want you to buy their expensive 200$ batteries. You can use a cheaper battery of same size with standard american terminal posts if you get replaceable cable adapters and swap the tiny ones out. I would watch a you tube video on that subject first if you attempt to do the job yourself.
    Warning, put a rag or something to block the hatch back latch so you don't close it with no 12V power. I did that and had to jumper the car to get it back open(shame on me LOL).
