12W LED H11 Bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Texas-Prius, Sep 13, 2012.
  1. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Has anyone replaced their H11 Halogen builbs with LED H11 Bulbs? There is a company selling them on eBay for about $40 a pair:
    2x 12W 4 OSRAM SMD LED Car Foglight Front Fog Head Driving DRL Light Lamp Bulb | eBay
    After doing a little googling, I found that a 12W LED is equivalent to 100W Halogen. If this is truely the case, then these bulbs should perform better than the stock Halogens, and draw a lot less power.
    I know that a lot of people are going to have a lot of opinions on this subject, but I'm not looking for opinions, but rather actual side by side comparisons done in the Prius headlight housings. I am not only looking for the difference in light output, but also stability (LED burnout, possible reflector burns, etc...). Please post pictures if you can.
    Thank you,
    - TP
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    There is no way you can use these as replacement headlight bulbs.
    Foglamps, yes. Not as bright, but they would work. More for aesthetics.
  3. Texas-Prius
    79
    32
    Austin, TX
    So if that's true, then the claims that are made (like 12W LED = 100W Halgen) are false. Does anyone know of a accurate cross reference to compare LED to Halogen wattage?
    - TP
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    A comparison of lumens would be more meaningful, that is if you could get accurate specifications on that.
  5. xliderider
    8,140
    3,280
    Honolulu, HI
    I'm getting a pair of LED H11 bulbs to use as DRLs in my foglights:
    LED foglights as DRLs, what 12v wire to tap? | PriusChat
    I'll post my impressions about how bright they are. I know ahead of time that they couldn't possibly be as bright as a 55w halogen bulb, but I'm just looking for a low wattage solution for a DRL, hopefully something that is bright enough to be seen in broad daylight.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Buy a pair and let us know how you like em.
  7. Texas-Prius
    79
    32
    Austin, TX
    You are correct. I thought about this later, after I had already posted this thread. You know, I've seen a lot of posts on LED driving lights, but haven't seen anything that broke it down in to lumens.
    I've done a bit more searching. The LED bulbs (the brightest I could find) were 400-450 lumens. To give an idea just how dim that really is, halogen bulbs rate anywhere from 1350-2100 lumens. So even the cheapest of halogen bulbs puts out almost four times as much light. Then there is HID which put out 2800-3500 lumens on average, while only using 35W of power after start up.
    So, based on this information, I would have to say that HID has a huge lead over LED. I have just ordered a couple of H11 kits to replace my high and low beams. I will be running 6000K on low beam and 3000K on high beam. This is the same setup I run on my motorcycles and the combination has always worked well for me.
    - TP
