134a Refrigerant in 2007 Prius - Compressor Damage?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cereboso, Apr 28, 2016.
  1. cereboso
    cereboso New Member
    Denton, TX
    Hello, my 2007 Prius was blowing warm air, so I bought a can of Interdynamics Artic Freeze Ultra-Synthetic 134a+ Refrigerant. This was recommended to me by the guy at O'Rielly's Auto Parts when I told him my car.
    This worked great and the AC is very cold.
    After use when I was cleaning things up I noticed on the back of the can that it says really small at the bottom "Not for use in hybrid/electric vechicles with non-belt driven (electric driven) compressor."
    Will this/has this damaged my compressor and is there anything I can/should do about it?
    Thank you!
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    First, you should go educate your parts store guy before he screws anybody else over.
    In response, in order.
    Likely. If not already, than soon.
    Take it to an A/C shop that has the proper equipment and knows the Prius. Have them do a complete evac and recharge. A little prayer may be in order. It's not the R-134a, it's the oil/sealant that's in it.
    Electric or combination pulley/electric (like on some of the Honda IMA cars) require non-conductive compressor oil. IIRC, it's a special ester blend instead of the common PAG oil used in most regular R-134a automotive systems. PAG is conductive, or at least it's conductive enough to potentially cause problems. Reports vary. Some claim no issues, others have had them destroyed due to improper oil.
    I recommend zero A/C use until you get it sorted.
    I made the same recommendation to an acquaintance who did the same thing on a Civic Hybrid.
    To be safe, I have separate sets of manifold gauges, one for non-electric, one for electric.
    TIFUMyPrius likes this.
  3. cereboso
    cereboso New Member
    Denton, TX
    Thanks for the reply.
    Would the "A/C PRO (HYB-134A) R134a Refrigerant Refill" from Amazon be a good one to use?
    The car only ran with the AC going with the bad refrigerant for a couple of minutes. Hopefully that wasn't enough to do much damage?
  4. cereboso
    cereboso New Member
    Denton, TX
    The can I used lists the following contents:
    18oz Refrigerant R-134a (1,1,1,2 Tetraflouroethane), 4oz of Lubricant, QuikBoost (R) A/C Performance Booster, System Safe Leak Sealer, O-Ring Conditioners and Acid & Moisture Eliminator.
    Can you confirm that those contents (and which ones?) are indeed damaging to my system?
    Thanks!!
  5. S Keith
    799
    329
    AZ
    2003 Prius
    Everything but the bolded part.
    In a Prius compressor you put only "pure" R-134a and the ND-11 or compatible compressor oil. Interdynamics makes something they claim is "hybrid safe" and compatible with ND-11 and one of the Honda oils. There may be other safe things to add, but I don't know what they are.
    EDIT: I think what you referenced on amazon is the same oil I linked+R134a.
    Your solution is to take it to a competent shop that understands hybrid compressor issues for a full evac and recharge.
    I think they're only about $1,600 to replace.
  6. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Too funny b/c you are screwed and in denial.
    Sounds like you are hoping to dilute the wrong refrigerant and hope that no damage has and will occur?
    What part of,
    is not understood? Doing this will give you the best possible outcome.
  7. cereboso
    cereboso New Member
    Denton, TX
    I'm not in denial, I was just trying to understand what's going on.
    I'm going to take it to a shop in the morning. I wasn't planning on just adding the other stuff and trying to dilute it.
    I was just asking about the other product for future reference in case I need to recharge it after cleaning it out this time.
    Thank you very much for your help.
  8. Stevewoods
    Stevewoods Senior Member
    664
    1,221
    where I am
    Just a warning. Many repair shops -- I will not say all, though I suspect that may well be the case -- will not touch a car that has been "recharged" by an amateur with refrigerant that contains a sealer.
    The chemicals will turn their fancy evac machine into a very sad, non-functioning unit. I just recharged the AC, but I made sure I got a can that contained only refrigerant. It did not work, so eventually I will take the car -- and the empty $11 dollar can of 134a to the shop and let them have at it.....
    I have already confirmed with them they will work on the car as long as I bring the empty can -- the shop owner and I have a long-standing relationship and he trusts me, just wants to look at the can himself to assure that it only had refrigerant.
    Good luck, Cereboso. You may need it. And do take in the can you used to the shop, if you haven't already gone.
  9. cereboso
    cereboso New Member
    Denton, TX
    So good news, I took the car to the shop today and they did two evacs and then recharged and they said they think it will be fine.
    Thanks again for your help S Keith.
    Hunters1 likes this.
  10. Stevewoods
    664
    1,221
    where I am
    Good news. Glad it got fixed!
