14 Plug-In not starting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by d_alpine_m, Apr 19, 2018.
  1. d_alpine_m
    d_alpine_m Junior Member
    31
    To start things off I disconnected the Aux battery in the rear - side and also removed the plug/key (orange thing) for the HV battery. I then proceeded to remove the inverter as well as the entire engine. Long story short i had the dreaded knocking misfire noise and Toyota wanted to replace my whole motor. I went ahead and did the work. I put everything back to normal but now when I push the start button all I get is a blank dash nothing shows up on my display. All my door lock switches, rear brake lights, etc dont work. I had my battery load tested and it passed with flying colors. I can hear the fans turn on for my HV battery. Any thoughts? Thanks in advance.
  2. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    Wow, read my last post (failing intake timing gear) did you have any of those symptoms.
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Check fuses related to the ECUs. Do you get aux power at the lighter outlets?
  4. scona
    scona Active Member
    225
    207
    Courtenay, BC, Canada
    2013 Prius v wagon
    This has happened to people here before. One of the most common fixes is to make sure that the safety plug is seated. It has to be snapped in properly to function. This video comments on it and how to ensure it is correctly installed. Good luck.....
    bisco and Raytheeagle like this.
  5. bisco
    52,767
    replaced the engine? how many miles on her?
  6. d_alpine_m
    31
    No I didn’t have any of those symptoms.
  7. d_alpine_m
    31
    I’ll check those later today thanks.
  8. d_alpine_m
    31
    Thank you I’ve check that plug numerous times and it’s seated properly.
  9. d_alpine_m
    31
    Original had 230k
  10. bisco
    52,767
    okay, thanks. that makes sense. agree with scone, did you slide the plug to the right after locking?
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    It seems like there's a clue here in that the battery cans run but nothing else. But I don't know what it would be Just for the fun of it, have you double-checked the 12V battery connections including the ground to the car's body and the small connector on the positive clamp assembly? Could be something loose maybe. Actually, it's surprising that you hear the HV battery fans because I never hear mine except at the end of a drive where I've been in EV mode doing 55 mph or more.
  12. d_alpine_m
    31
    Yeah I made sure it has a connector with two pins that connect.
    I made sure all connections were in tact on the battery. I even checked to see if any of the other connectors on the hybrid batt were loose. I only hear the fans because that is all that is coming on when i depress the brake and press power.
  13. bisco
    52,767
    not sure what you mean by 'connector with 2 pins that connect', but the orange safety plug needs to be inserted, snapped down, and slid to the right.
  14. d_alpine_m
    31
    Yeah that orange safety is inserted and snapped down. That part that sings to the left and slide in to snap has a connected with pins in it, once you slide it in the pins are inserted to the connector on the opposite end.
  15. bisco
    52,767
    anything happen when you plug her in? do you have tech stream?
  16. jerrymildred
    11,517
    14,164
    Tampa, FL
    Where are these fans? Mine does not run any fans except the hvac if it's turned on. If I don't have the radio, the vents, or the AC running, when I power up, it's silent except for the chime if I haven't yet closed the door and buckled up.
  17. bisco
    52,767
    and the brake accumulator, but that's just opening the door.
    jerrymildred likes this.
  18. jerrymildred
    11,517
    14,164
    Tampa, FL
    Right. It's usually done by the time I pop my phone into it's bracket.
  19. d_alpine_m
    31
    Ok just wanted to update this. I ended up taking the car to the dealership and was told it was a fuse under the hybrid computer. Along with the timing being off by 3 teeth. Also in their possession they found the air fuel sensor bad and it was also replaced. I called them yesterday to pick up the vehicle and they said it was ready to go. I end up starting the car in their lot and step out to speak to the service rep. Once i get back in the "Check hybrid system" is on. I left the car there and today got a call from the service guy explaining to me that the inverter is bad and was a result of wires being crossed from the original repairs when i replaced the motor. It really doesn't add up to me and the service rep tells me that the "check hybrid system" doesn't show up right away.
    Are there any hybrid service techs on here that can tell me that the inverter after it has crossed still work and not show the issue right away once the vehicle is started and driven for about 20-30 miles? Is it even possible to start the car with a bad inverter?
    just a little recap:
    Service rep tells me that the wires of the inverter was crossed before they got the car which resulted in a bad fuse. The dealership receives the car fixes the fuse and other little things and drive the car around a supposed 20-30 miles with no issues result in "check hybrid system". Soon as I start the car after paying for service the "check hybrid system" shows up and get a phones call telling me the inverter is bad and it needs to be replaced.
    Sorry for any grammatical issues just frustrated and feeling the like the dealership is pulling a fast one on me.
    I would think its common sense that the issue will show within those 20-30 miles driven by the dealership or right away when they start the car, but according to the service rep it doesn't work that way because its a hybrid.
    "calling any hybrid service techs please help"
  20. bisco
    52,767
    what does 'timing being off by 3 teeth' mean? the timing chain inside the engine?
    Raytheeagle likes this.
