14 Prius v (lowercase v for the Prius v wagon, not uppercase) ghting up n other lights on
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by batis, Jan 11, 2017.
  1. batis
    batis Junior Member
    I'm having an issue with my 14 Prius v (lowercaes v for the Prius v wagon, not an uppercase v) my rear tail lamps are not lighting up and the 3rd break light too. I also have the traction control light on the dash, break light and abs light on.
    these are the codes the car is currently throwing:
    C1242- Open Circuit lG1/IG2 Circuit
    C1247- fault in Stroke Sensor
    C1249- Open Circuit in Stop light Switch Circuit
    C1252-Hydro Boost Pump Motor Fault
    C1311 -Brake Inhibit Relay Open/short/ main relay 1 circuit Open
    C1380 -Fault in Stop light Relay System
    C1445- Vehicle driven with steering angle sensor not Initilized
    where is the the IG1 Relay located?
    Is there a Prius Mechanic in the LA/OC (california)area I need help fixing my car.
    all info is appreciated.
    thanks,
    [​IMG]subir gif
    [​IMG]imag
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    2014? Still under warranty?
    If not, $15 for a day with and downloading Toyota Tech Info would be a worthwhile investment.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,983
    4,726
    Texas Hill Country
    It sounds like a system level problem, most likely power related. 12 v battery or inverter would be my guess. I doubt there is a BREAK in the BRAKE circuit.
    #3 rjparker, Jan 11, 2017
  4. batis
    batis Junior Member
    is the 12V battery the battery that is on the right side of quarter panel?
  5. rjparker
    7,983
    4,726
    Texas Hill Country
