142MPG? I need some help here.
Discussion in 'Gen 2 Prius Technical Discussion' started by anti-gas, Apr 1, 2008.
  1. SpartanScott
    SpartanScott Michigan Member
    60
    Howell, Michigan
    I do use your method as a rough estimate. I figure 8-10 gallons depending on the temp. Although the "guess gauge" is inaccurate, it is very predictable. I notice that the first pip takes about 120 miles, then the last 9 get 35-40 miles per pip. You should observe to see if this is true for your driving. I'd say you are 98% safe by saying you have 30 miles left when it changes to 1 pip, but all bets are off when it starts to blink. This depends on your mileage of course.
    anti-gas, I notice that the miles I can drive with a "full" tank depend on the outdoor temp when filling. With temps above 70 I usually get 130+ miles, and with temps below 20 I get less than 40 miles before the first pip goes. If you really put in 12+ gallons and it was a hot day, 150-250 miles would be normal. I too agree that the MFD screen MPG is 99% accurate(not perfect due to rounding errors). I might use my hand calculated for lifetime MPG but that's it. Gas pumps will charge you for more gallons than you actually put in. Pumping slow is the only way to get your bucks worth.
  2. anti-gas
    anti-gas Reduce, Reuse and Conserve
    56
    South Florida
    I refuel at either 2 bars or 350-400miles give or take, but this is my 4th fill up so I'm still experimenting. I'm getting 49.869mpg calculating lifetime mileage using the total cumulative miles driven/total cumulative gallons filled. I don't trust the computer to give me true results although I'm sure it is close from what I have seen so far.
    My friend drives from Fort Lauderdale FL, to Atlanta, GA which is 680 miles one way. He said he fills up about 50 miles into GA which is quite a ways. He also is getting 55.4mpg average miles in the car, but he only drives it on the highway at speeds between 55-64mph on cruise control. (non-traffic hours). This was his lifetime calculation. I will be doing that trip come November and will see the difference 3 more passengers + lots of cargo make on that fuel economy. I'm expecting 49-53 based on my local highway results with a heavier load.
    If you always assume you only have 9 gallons of fuel in the tank when full, you know how far you can go before a fill-up. That's what I do. I like lots of reserve! This may be why I have never run out of gas in all the years I have been driving. I once had a car with a broken sender unit so my Fuel tank always read 3/4 of a tank. I used my ODO to know when to fill up. Did that for 8 years, never had a problem. Once you know your car, you KNOW your CAR.
    My car and I are still sniffing each other out, Its only been 6 weeks now since we met. :thumb: And we are getting along as good as expected, actually a little better. Oh and the family is very happy too, as I went from a big Toyota 4Runner, done to a small econo-box, which really isn't as small as you may think. Wish I did this 10 years ago! All I can think about is the $40K in gas I would have saved!
  3. Patrick Wong
    18,210
    6,517
    So - what did you decide? Did the gasoline station pump cheat you; or is your Prius fuel tank larger than normal?
  4. anti-gas
    56
    South Florida
    I am down here in S.FL. Temps here upon fill-up are around 78-88 with 80% or higher humidity. My first few fill-ups the temps were in the 60's to low 70's with mid/high humidity. I am going to wait until I get 380miles before I bring it in for service. By then the gauge should have adjusted. I know my 2nd fill-up the gauge didn't drop a bar till 129 miles, but the 2nd bar dropped about 30 miles later, then it leveled off. I generally don't use fuel gauges as anything but a guide, but I always reset and monitor my trip ODO as I know my cars and how far they can go before they require a thirst quenching. Thanks for all the tips and comments out there. You are a great bunch of people. I can only hope in the months to come, I can give some great tips/advice to other out there as well.
  5. anti-gas
    56
    South Florida
    Oh, forgot to report on that. I pumped 5 gallons on the digital pump and received just over 4.75 gallons in my container. I argued with the store clerk for a very long while and demanded that they refund 100% of what I had pumped as this should make up for the last fill-up I got ripped off on. He called the owner of the station on the phone which I demanded and he assured me that his pumps are 100% accurate in what they charge/pump as they have to meet strict guidelines for the state of FL.
    I then told him that my good friend is the one who inspected your station 17months ago, and you know, that was a long time ago, its time for another inspection. I called up my buddy who is in this territory and he came by, unfortunately, after I had left the station and his report stated it was accurate, however he said the owner may have adjusted it afraid of getting caught, because a lot of stations around FL have been cheating the customers by pumping less that what the meter says. He said he will go by there and make 2-4 more inspections over the next few weeks to try and catch him cheating the customers. Unfortunately, the only thing he can do is shut him down till he gets it re-certified because he can't prove willful wrong doing. Based on that, I think I was overcharged by 1.5 gallons of fuel give or take. That in my book is almost $6 per fill up.
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    + 1 when making a long distance trip it is best to start thinking about a fill up with about 2 pips remaining. When on the road I don't always know where the next gas station off the highway is, so when it gets to two pips I take the next exit w/ gas.
  7. patsparks
    10,664
    569
    Adelaide South Australia
    Isn't this stuff normal in the USA?
    We had a bit of a drive yesterday in the Holden (GM) Commodore I drive for work so I thought although we still had just under 3/4 of a tank we would fill up. Put 44 litres in the 80 litre tank!! It is normal for a fuel gauge to go down in a non linear way and it's normal for the gauge to stay at full for a while after filling.
  8. spf
    spf Junior Member
    70
    Spartan et al,
    Thanks very much for the helpful advice.....it is greatly appreciated!
  9. anti-gas
    56
    South Florida
    Quote:
    "anti-gas, I notice that the miles I can drive with a "full" tank depend on the outdoor temp when filling. With temps above 70 I usually get 130+ miles, and with temps below 20 I get less than 40 miles before the first pip goes. If you really put in 12+ gallons and it was a hot day, 150-250 miles would be normal. I too agree that the MFD screen MPG is 99% accurate(not perfect due to rounding errors). I might use my hand calculated for lifetime MPG but that's it. Gas pumps will charge you for more gallons than you actually put in. Pumping slow is the only way to get your bucks worth."
    I just had a one PIP on the full gauge disappear in the display finally this morning. That was at 179 miles so I guess my gauge is operating normally. My question to you is you mention to Pump slowly to get your $$ worth. Why is that? Should it not register the same volume fast or slow? If you can expand on this, it would be very informative. Either way, I will give it a try.
    Thanks.:rockon:
  10. SpartanScott
    60
    Howell, Michigan
    I'm not sure if it's a proven fact, but it has been stated here on PC many times. The pump meters the volume flowing. Pumping fast will might cause turbulant flow so the pump would count air/bubbles/foam as gas volume. I'll let someone else back me up with facts here. I don't believe this can account for ani-gas's 5% error in his 5 gal test. His station is most likely messing with the pumps.
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I doubt the pump accuracy changes much due to flow rate. The meter is a displacement type, and the fuel doesn't bubble until it drops out of the nossle (unless the underground tank is almost empty). The main reason for refilling slowly is to get a bit more fuel in before shutoff, and to avoid a lot of bubbles in the tank that have to "bleed off", possibly causing a burp out.
    Always remove the nossle slowly, just in case. I even depress the nossle down to create a gap in the seal at the top to bleed off any pressure that -may- spit out fuel. If you find yourself in this situation (fuel trying to spit out), be patient. The pressure can be bled off slowly without much fuel loss. Pearl has only spit on me twice, both times due to a faulty filler shutoff. The -second time- (yes, I learn from my experiences) I avoided fuel spillage by being patient.
    Be aware you can't use the last gallon or so of fuel in the tank. Unless you are shaking the tank. There is a cavity in the tank system where the fuel pump resides (for cooling and to ensure it is always pumping fuel and not air). Contaminants also settle out there (below the pump). Also note, it -may- be possible to overheat the fuel pump by running out of fuel, though the fuel pump in the Prius will shut off if the engine dies, so it is a little less possible to burn out the fuel pump in a Prius than in other cars.
    This cavity also causes what some owners who have run out report - you have to put in at least two gallons to get the thing running again.
    Running out of fuel in a Prius is not a "good thing" (tm). Better to avoid that situation. I fill up at around 1/2 tank if in the city. On the highway I fill up at 1/4 tank if possible. Besides, it's fun to fill up the Prius. Perhaps because my previous vehicle was a Nissan Pathfinder (the anti-Prius), which took 80 litres of Premium! Around $100!! Pearl usually takes $20 to $30 of regular. :)
  12. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    Hey, all,
    I always fill up when I get to only 2 pips remain'g (once it got down to one pip before I could find an open station---I didn't like that feel'g). I have an '05 that automatically resets BOTH the MPG & miles-between-fillups on the screen ('04's do that too). In the winter I go between 350 & 380 miles before the 2 pips. In the summer it goes up to between 400 & 430 miles before getting down to the 2 pips.
    I think on the '06 though '08 models only the screen miles get automatically reset at fillup because the MPG is left alone each time to maintain a "lifetime average MPG" (a throwback to the way the early adopters preferred it in their '01 through '03 models).
    My point is this : either fill up at 2 pips all the time (to be safe) or if you're going to do the calculations of MPG times the # of useable gallons you feel comfortable with (because of the bladder, more in the summer & less in the winter), then give up on your lifetime MPG (keep your own records on a pc spreadsheet) & do a manual reset (of the MPG) at every fill'g.
    My reason'g is this : on an '06 through '08 car (lifetime MPG) with many miles on it, the lifetime average will probably be pretty high. So unless you reset your MPG at every fill'g, one tank that gets affected by an extreme drop in temp or new hilly terrain won't show too much of a drop on a lifetime average display but will certainly reduce the # of miles you can safely travel without running out of gas.
    Let me use an example. Let's say your lifetime average indicates 52 MPG (lucky you) & you don't ever reset your MPG's on the screen. Let's also say that it's warm weather, but you haven't really noticed that on this tank you've been doing a lot more stop & go (read that "warm up") cycles & you've also been in some hilly terrain. If you HAD reset at the start of this tank, you might find your MPG for THIS tank to be only 40 MPG. If you HAVEN'T done a reset then this one "bad" tank might only bring your lifetime MPG down from the 52 to an indicated 50 MPG. That would mean a difference or "error" of 10 MPG [indicated 50, LIFETIME minus REAL 40, on this tank only (WITH the reset)], times 10 useable gallons (you're think'g the 10 gals because it's warm weather, remember). These calculations would lead to 100 miles less of useable travel than you think you safely have.
    That's why I'm glad my 2005 automatically resets BOTH MPG & MILES at each fillup. I just look at my true MPG (from the car's own calculations of fuel actually put through the injectors) & I can pull out my logbook of how many gallons I added at last fillup & multiply those gallons times my MPG & fillup before my miles on screen reaches my calculated "safe" miles. It's fairly simple to do but mostly I just refill at 2 pips & it's within the ranges I stated above in the 1st paragraph. I've never run out of gas yet & I don't intend to.
    Also, you should go to the main forum & find the thread entitled "When do you refill?". It's a poll, so vote, view the results, & then read all the comments there. See other like topics or threads (usually found way down at the very bottom of the page).
    Ken (in Bolton,Ct)
  13. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    THIS brings up an interesting point. my FIRST pip disappears at about 60 miles driven. My computer says my mileage is about 46-47 mpg.
    is this normal? i was not too concerned about this until i read this thread.
    thanks for any input,
  14. Patrick Wong
    18,210
    6,517
    The point at which your top fuel gauge segment disappears depends upon how full you make the tank. Some people can go 150 miles or more because they fill the tank way beyond the first pump click off.
    Your car is "normal", given the variability caused by the bladder, production differences etc.
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    you are normal, people getting significantly more than this are overfilling. in summer, you will notice getting 80-110 miles on the first pip, again, that is in the normal range. getting less than 80 in summer, is nothing to be alarmed at but getting significantly more than 110 miles should be addressed.
    after 4 years, i can tell you, if you are stopping at the first click (or near it. you should always have an idea as to how much to put in based on your MFD display assuming you manually reset after every fillup) you will be in the normal range.
    now there are too many people who want the 11.9 gallons in the tank. well, lets face it. we are all basing this want and need on previous vehicles we have owned. once again, american car manufacturers have come back to haunt us. i read many stories about disappointed Prius owners relating stories about how their gm had a 20 gallon tank and they were able to put 20+ gallons in it because of the "reserve" all the while discounting advances in technology on Toyota's part, the lack of quality control on gm's part, etc.
    you cant have your cake and eat it too. Toyota's biggest mistake was reporting the tank size in the first place. their 2nd biggest mistake was assuming that we would be happy with a vehicle that had essentially the same usable range as our previous vehicle. (ya thats right, even when we have only 9-10 gallons of usable gas that still gets us the same distance as our previous car)
    now maybe they should use a tool like my GPS system, it has a digital gauge for miles to turn, miles left in total trip, etc... when i am 1000 feet away from my turn, an analog gauge pops up so i can see the rate i am approaching the turn, makes it nearly impossible to miss a turn. now if Toyota were to incorporate something similar in their gas tank, maybe that will prevent people from ignoring the warnings to get gas. just have a mini analog gauge pop up when the last bar starts to blink...
  16. Genoz World
    797
    22
    La Canada
    thank you! i'll just nevermind this and keep driving.
    safe driving and cheers.
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    another quick comment...the filler tube is exactly that, a tube used to fill the tank... its not a "storage" tube. so if you see gas in the tube, you are in the process of destroying your fuel storage system.
  18. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    On a recent trip I noticed the gas gauge didn't drop one pip until I had driven over 180 miles after filling the tank. I think it's normal for the Prius.
    jd
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The pumps meter the same at slow or fast settings. The difference in flow is not enough to change the physics behind the operation. This advice is one of a whole bunch of urban legends involving gas stations and fueling.
    Tom
  20. racerbob
    racerbob Member
    138
    S Florida
    anti-gas,
    Do you have bigger wheels/tires perhaps?
