145k must dos
Discussion in 'Gen 3 Prius Main Forum' started by H.S., Jun 19, 2026.
  1. H.S.
    H.S. Member
    118
    26
    Venice, ca
    Hello all. My gen 3 Prius is approaching 145k and wanted to check what are the must do maintenance , not precautionary at that milestone ? I am trying to find a good and reasonably priced mechanic in the Los Angeles area- recs always welcome
  2. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    1. Check for EGR restriction the easy way: Techstream EGR Valve Blockage Data | Page 3 | PriusChat.
    2. Clean out EGR ports of intake manifold, if that hasn't already been done.
    3. Prepare to change spark plugs and engine coolant, if they haven't been changed already.
    4. Normal stuff like oil changes ...
    How much engine oil does it consume? Monitor coolant and oil levels closely.
  3. Brian1954
    Brian1954 Senior Member
    2,660
    1,064
    South Central PA, USA
    It all depends on the maintenance that has already been done on the car. It appears that you get all the work done at a dealership. Do you keep the receipts from the previous work that has been done? If so, make a list starting with the most recent work done and the mileage when it was done. Continue doing this for the last 5 years of work done. Then, make a new post and write down all the work that has been done for the past 5 years so that we can make recommendations for what work should be done now on your car.
    You make the same request every 5k to 15k miles, but you never give a list with the work that has already been done on the car.
    #3 Brian1954, Jun 19, 2026
  4. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    I also just scored a Gen3 with 145K miles recently. Revived it from the dead... My most recent thoughts have been on monitoring coolant system temps, especially electric water pump operating temp in new and unique ways... Also I have a failed AC condenser so I plan to replace the radiator at the same time will keep a spare pump on the shelf.
    Also been researching oil catch cans and learning about how to clean and inspect ABS sensors and suspension and drivetrain once I get it up on jack stands...
    And if you haven't done it yet new spark plugs and intake system cleaning is a good opportunity for a borescope to gauge engine lifespan by seeing what the insides of your engine look like. I bought a really nice $50 scope that plugs into my phone on Tiktok for like $8.
  5. Mendel Leisk
    42,273
    Attached is a table-format summary of the Toyota USA 3rd gen schedule, extrapolated to 240k miles, a little easier to read. That should hold you for a while.
    Also worth considering:
    EGR cleaning
    Transaxle fluid change
    Brake fluid change
    Hybrid battery fan cleaning
    Throttle body cleaning
    Alexikor likes this.
  6. H.S.
    H.S. Member
    118
    26
    Venice, ca
    Thanks for sharing - according to this there isn’t much but visual inspection at 145k
  7. Mendel Leisk
    42,273
    Yeah, visual inspection of brakes, while doing tire rotation. Again, this is just verabatim conversion of Toyota's Warranty and Maintenance Booklet schedule, extrapolated past 120k miles.
    H.S. likes this.
  8. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    We are at the same boat. let me share your post and some questions
    My prius @ 140K now
    @ 98k, EGR cooler/pipe cleaned, Transmission fluid changed, Inverter/engine Coolant changed. 4, spark plug changed. Manifold cleaned, Oil catch cans installed. Hybrid battery fan clean.
    @ 125k, Water pump changed, break fluid changed, 12v battery changed. Recondition hybrid. battery. Manifold & OCC cleared.
    Now @ 140K, should I clean my EGR cooler again? Hybrid battery discharge & rechange so quick. Repositioning the inter battery module with outer battery module can help?
