15” wheels on a v
Discussion in 'Prius v Main Forum' started by broncobilly_69, Jan 20, 2018.
  1. broncobilly_69
    broncobilly_69 Junior Member
    Corvallis, OR
    2017 Prius v wagon
    Anybody know if 15 inch wheels will fit on a v? Tires for them are about $80 a piece cheaper than for my 17” wheels.
    iPhone ?
  2. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I think you'd have to fit them to be sure. The issue with wheel fitment is generally whether the wheel will contact the brakes. You may know this already, but the V doesn't share wheels with the standard Prius. Standard Prius has a 5 x 100 bolt pattern, the V is 5 x 114.3.
    The 5 x 100 pattern is common with compact Toyotas: Yaris, Corolla, etc.
    The 5 x 114.3 pattern is common with midsize Toyotas: Camry, RAV4, etc.
    mollymudpie and broncobilly_69 like this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    You'd also need to keep in mind load ratings for the tires. In general, smaller tires have lower load ratings. The v is roughly 300 lbs heavier than the regular hatchback, which has 15 inch wheels on everything but the top of the line level five.
  4. Rmay635703
    Rmay635703 Senior Member
    2,689
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    15” Tires are a great idea , if I had a v I would run 15’s if I could.
    I would not worry about weight rating, my Diesel suburban runs 15” wheels and is about twice the weight of the v, just run higher PSI in the tire if you select a smaller OD than your stock wheels.
    There are websites that list the stud spacing, offset, rims and tires for all cars . You can search for what models share your lugs, my guess is honda/Hyundai are likely suspects.
    If you can find a U PULL junkyard lookup a car that uses your lug spacing with a rim you want, break out $25 and test the rim on your car.
    My guess is 15’s would fit the rear but not the front unless you can find a rim that has a lot of negative offset.
    Generally the only rims like that (negative offset) are extremely heavy space saver spares. (15” Steel space saver rims are very strong but about twice the weight of a similar alloy rim)
    I have had all space saver rims on my Cobalt with 14” Re92’s and actually they worked great, just a little ugly until I painted them with a pattern of rust oleum hammered steel paint.
    Good Luck and if you find something that works let everyone know.
    #4 Rmay635703, Jan 21, 2018
  5. broncobilly_69
    Corvallis, OR
    2017 Prius v wagon
    Slid the finger gauge between the wheel and caliper on the front yesterday. Got two fingers in, which with my girly hands is about 1.5”. Should have 1/2 in clearance, I’ll definitely try them on before I purchase. Keeping an eye on CL for a deal on a set I like.
    Saw some nice 16’s off a mustang that would fit.
    iPhone ?
  6. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Good luck with the search. I got lucky and got an almost new set of mounted winter tires/wheels on CL from a former Prius V owner -- so I knew the fit was fine.
    Post back with what you get and what they came from. It's always good to know what will fit from other makes/models.
    broncobilly_69 likes this.
  7. waldox
    waldox Junior Member
    69
    toronto
    the 16" oem alloys on the V barely fit the rear brake calipers, only about a pinky space inbetween rim and brake caliper
    15" steel rims may fit as they are thinner than the oem 16" alloys, but check the rear as they are the likely causing fitment issues.
    front has plenty of space with 16" alloys
