15 inch wheel question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Apatel1101, Apr 6, 2019.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I am interested in buying a wheel that is 15x6j 38offset. Would this work on the 3rd gen prius which are 15x6.5j 45 offset. I have attached picture of the stamp that is on back of the wheel i want to buy.
  2. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    the numbers look fine. just make sure its 5x100 and you probably have to get a centric ring adapter. However, just from looking at the 2nd pic, the base of the bolts and the blade spokes look very shallow. You might need to get spacers in order to clear the calipers from hitting. I have to always put 3mm spacers when I use my FRS wheel set in the winter.
    Apatel1101 and marvingloria2011 like this.
  3. Mendel Leisk
    42,343
    Post a clear picture (or type) the brand and name of the rim.
    Or just go to tirerack, enter your car details, say you're shopping rims. See if that rim comes up. If not, start again without entering your car details, see if they've got that rim. If so, likely not compatible.
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    Brand : mb wheels
    They are 5x100 with 38 offset @Starbrand
  5. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I tried it on and it clears the caliper. Just need a suggestion on the lug nuts.
