15 mpg less after head gasket job
Discussion in 'Gen 3 Prius Fuel Economy' started by CharlesPrius, Aug 7, 2018.
  1. CharlesPrius
    CharlesPrius Member
    154
    60
    Had my head gasket replaced last week yay. Had thrown cyl 2 misfire code. Anyway that issue is fixed and no more coolant loss. I C Engine sounds good. However, before the job, even with the engine throwing codes and hesitating and losing coolant, I was still getting 52-55mpg. Since I got it back I'm only getting 38-40 on this first tank. I'm hoping it's just due to hot weather and a/c usage or very low tire pressure. But 15 is a huge dropoff. Could they have forgotten to hook up a wire? Or screwed with the throttle cable?
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Could be many things. But maybe they drove the car some and/or let it idle to make sure it wasn't leaking.
    Check your next tank full and see what happens. Did they clean out the EGR system and intake manifold also?
    #2 ASRDogman, Aug 7, 2018
    CharlesPrius and Raytheeagle like this.
  3. padroo
    padroo Senior Member
    2,763
    2,253
    They probably had the battery disconnected and it has to go through its relearning procedure. Be patient .
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    As long as you have no Check Engine light, I wouldn’t worry about it too much. I just changed my engine. The first 20 miles, it was showing less then 30 mpg. I beat it up pretty good to make sure all was well. I topped it off with gas and reset the trip meter. I’m running 58.7 mpg at 200 miles post engine change.
    padroo and CharlesPrius like this.
  5. bisco
    52,891
    how did you calculate 38-40? when i fill up and divide the miles driven by gallons pumped, it comes to an exact number.
  6. CharlesPrius
    CharlesPrius Member
    154
    60
    That's a good relief, thanks. I'm at about 55 miles since fillup and it's showing about 38mpg. GIven this is mainly stop-go driving and a/c on all the time (been unusually hot here).
  7. CharlesPrius
    CharlesPrius Member
    154
    60
    The computer readout/estimate (mpg) is what I refer to. Later I will do it manually yes, but the cpu has usually been within 1-3 mpg of that.
  8. bisco
    52,891
    how many miles have you driven since getting it back? did you reset the mpg when you got it?
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    IF......your "before" figure was a long term average, it probably got reset and what looks like a sudden drop might not as bad as it looks.
    Give it some time.
  10. CharlesPrius
    CharlesPrius Member
    154
    60
    I would consider myself a dolt of the highest order had I not reset my trip odometer at my last fillup. So yes, the 36-38mpg I'm getting is for this tank only. So far it's at 70 miles. Hoping it's just a "the battery needs time to relearn / reprogram itself" issue and not something else.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    [QUOTE="CharlesPrius, post: 2765465, member: 153916" So far it's at 70 miles. .[/QUOTE]
    That is not enough time; not nearly enough.
    Get back to us after the first 3 tankfuls.......and a manual calculation. (y)
  12. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Find a highway loop that you can easily access. 20-30 miles one way. Set your cruise and reset trip b. See if the calculated mileage is close to what you remember the car doing before the head gasket job. Also watch for the check engine light. It’s possible the when the head gasket was done the timing chain could be off one tooth. The intake VVT can adjust for that some in town, but the highway RPM would show it, and give you a check engine light.
    Did the shop do the job with the engine still in the car? I personally would not have done the job without pulling the engine, due to how hard it is to verify the timing marks.
  13. CharlesPrius
    CharlesPrius Member
    154
    60
    Thanks for the tip. I live in West Los Angeles so I might have to go to Arizona to find such a stretch of road (haha). No CEL yet, engine sounds strong.
    Pretty sure they pulled the engine. Head had to be machined a bit, and they sent it away for that. Though I wasn't watching while it was done.
  14. 1Greensix
    1Greensix Junior Member
    Atwater, ca
  15. 1Greensix
    Atwater, ca
    I’ve had the exact same problem. A year ago, I had my head gasket replaced at Merced California Toyota dealership. I normally drive highway speeds of 75 to 80 in California and I would get 45 miles per gallon. Now I’m getting 34 to 36 miles per gallon. So I’ve lost nine or 10 miles per gallon, simply because I had them replace the head gasket.
  16. nicoj36
    nicoj36 Active Member
    518
    162
    Try this reset
    mikey_t and Mendel Leisk like this.
