15 or 16 inch rims?
Discussion in 'Gen 2 Prius Main Forum' started by Billinak, Aug 27, 2009.
  1. Billinak
    Billinak New Member
    Anchorage, AK
    I have a 2009 Touring model and I'm getting studded tires on rims for the winter here in Anchorage. According to the guys at the tire shop, I have the option of 15 or 16 inches wheels/tires. I was considering the 15 inch setup due to the price, but can anyone see any issues with going with the smaller size?
  2. kkayser
    kkayser Junior Member
    49
    Bigger tires burn more gas.
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    To be precise, bigger wheels -- usually heavier -- and slightly wider tires
    burn more gas.
    Technically, this is correct. Theoretical MPG reduction may be as much
    as 4% or maybe 2 MPG. Keeping the tires filled to 42psi front/40psi rear
    goes a long way to overcome this. On either size wheel, the choice of new
    tire can result in a loss of up to 6 MPGs -- there are usually other pluses
    such as improved handling, less noise, better braking, etc.
    In everyday driving the combination of variables such as temperature,
    traffic, topography, route, tire pressure variations, and even driver attention
    level make it virtually impossible to "isolate" this small fraction of overall
    MPG/FE.
    A more significant difference is there are considerably fewer tires on the
    market to choose from for the OEM 16" tire size.
    There are many threads discussing the relative merits of the two wheel/tire
    sizes and numerous tires. The search tool is your friend!
  4. Billinak
    Billinak New Member
    Anchorage, AK
    Thanks folks, I figure on losing some MPGs with the studs, but maybe I'll gain a few back going from 16" to 15".
