15 Prius v ( lowercase v for the Prius v wagon, not an uppercase ) changes
Discussion in 'Prius v Main Forum' started by FLbill, Jan 7, 2015.
  1. FLbill
    FLbill Junior Member
    26
    Orlando, FL
    2015 Prius v wagon
    I just bought a 2015 v 5 w/tech pkg. I traded a 12 v 2. Generally, the 15 is basically the same car with the already noted exceptions. However, I have one that has me baffled. In the 12, when the ODO was displayed, the avg MPG was also displayed, and it was consistent 49-50. I appreciate it was a point or two over actual, but it was relative. The 15 is different in that with the ODO displayed, the mpg is reset with each restart and it seems to start low and under-represent (4-5 points) the actual mpg. Has anyone else seen anything different or know of how to set options? Ideally, I would prefer the display to be as the 12.
    The only other comment of note regards the new LED? accent light around the headlight assembly. I has hoped it would also be present with the DRL, and it is only present when the headlights are on. The new lighting really looks great, so I would like to have it on with the DRL or alone without DRL. Does anyone know of any options for the setting of the new lights?
    Thanks in advance.
    49,511
    nice styling updates though. big improvement, especially the nose.(y)
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Set the ODO to trip meter and zero it when you fill up. That should give you the average for the tank.
  4. FLbill
    26
    Orlando, FL
    2015 Prius v wagon
    Thanks. I will see how that computation works out.
