150,000 coming up and I've got some questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sterlingarcher6969, May 13, 2022.
Tags:
  1. Sterlingarcher6969
    Sterlingarcher6969 Junior Member
    64
    22
    Hi everyone just hit 147k last week and I've got a laundry list of things I wanna get done.
    The thing is, most of these I don't want to diy so I need a good repair shop within the California bay area, any suggestions?
    Disclaimer: I bought the car at 128k and very few repair records Beyond oil changes.
    What I want checked/fixed
    Egr circuit ( I still get 47mpg city and I have a lead foot, so maybe this can wait? Idk)
    Spark plugs
    Shocks (some of the rubber grommets are missing entirely)
    Transaxle fluid change
    Fuel filter
    Oil change (may as well, I change every 3k)
    Maybe install oil catch can? (This is a weird one I was burning maybe a quart every 3k when I bought the car but now it doesn't anymore after I used the techron fuel additive. Wasn't expecting it to actually work lol)
    I think that's all for 150k let me know if I missed anything super important
    Tombukt2 likes this.
    52,863
    luscious garage and arts automotive.
    see if your cr has the updated pistons and rings. it goes by vin.
    Sterlingarcher6969 likes this.
  3. nicoj36
    nicoj36 Active Member
    518
    162
    Dont forget coolants
  4. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I'm interested in 53,000 miles from now how long will that take you to do right you'll be out of the car probably you should make it to that pretty uneventful stuff even if you didn't do what you have on the list you'll still probably make what I'm saying.
  5. Mendel Leisk
    42,355
    Don’t hesitate or delay; you’re at least 47k overdue now.
    Foxglove likes this.
  6. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    New sparks
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No oil filter change on the list. Born to be wild!!!
  8. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    I would get your brake caliper pins checked/re-greased.
  9. Sterlingarcher6969
    64
    22
    Sorry for the late reply.
    I do get a weird croaking/creaking sound when letting off the brake. But only when I'm parked in my driveway and am reversing out. It's pretty loud
  10. Sterlingarcher6969
    64
    22
    Darn ok I'm saving up currently.
  11. Sterlingarcher6969
    64
    22
    I don't quite understand what you are saying
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,976
    Texas Hill Country
    He wonders if it will still be running at 200k. He thinks it will even if you neglect it.
    He's from North Carolina.
  13. Mendel Leisk
    42,355
    Something weird happened with the quote function:
    Yeah being obtuse; what I was trying to get across, is at 147k, there's no point in waiting, get the EGR cleaning started ASAP, it's better done by 100k, so overdue.
    And yeah, Toyota's totally passive-aggressive on this, says everything's fine, till you've got cold-start shakes and/or (restricted EGR flow) code.
    #13 Mendel Leisk, May 18, 2022
  14. Tombukt2
    13,864
    2,519
    Durham NC
    I'm watching I've got a clean one right now installed and I'm going to keep an eye on it real good fashion because it's easy to disassemble and look at on the one end very quickly so no issues going to see how fast this thing clogs up I have another one or two going out to the machine shop to be tanked and clean properly
  15. Sterlingarcher6969
    64
    22
    oh ok yeah, I think it will easily hit 200k if I do nothing (not doing that), I'm tempted to just take the egr pipe off to see how bad it is. maybe the previous owner did the job but it wasn't in writing.
    searching around egr job at a shop would cost 1000$ alone, not including the other things I want done. i just don't have the cash right now. i probably will by the time 150k comes around.
    I've been studying some vids on diying the egr job but I'm going to have to be quoted like $2k for me to consider that.
  16. Sterlingarcher6969
    64
    22
    i was referring to Tombukt2's reply sorry for the confusion
  17. Mendel Leisk
    42,355
    Yeah somehow, you quoted @Grit, but it's my text, lol. Just technical, not relevant to discussion though..
    Not that difficult to DIY, or if you can enlist a shade tree mechanic. No parts need replacement; it just takes patient cleaning. See first link in my signature.
  18. Sterlingarcher6969
    64
    22
    I finally got an update for you guys. I did some of the egr job but stopped short of the actual egr solenoid and cooler. I just don't have hands small enough haha. In the future I'll just buy a new cooler and solenoid and have a mechanic put it in.
    However I have good news! I think it's Been done before I bought the car. There was VERY little build up on the intake and egr pipe compared to what I've seen on tutorial videos At most maybe 1.5mm and only in select areas.
    Got everything put back together minus the wipers bc Im still waiting on the spark plugs.
    First time I started it up after reassembly there were some real scary noises and I quickly turned the car off my dad who was a mechanic in the 70s says it sounded like knocking, and was struggling to keep running.
    Turns out In my excitement to get the car back together my dumbass forgot to reconnect the tube going from the intake manifold to the pcv valve.
    Runs fine now(hope it didn't cause permanent damage)☹️[​IMG]
    nicoj36 and bisco like this.
