1500W 120V AC outlet
Discussion in 'Gen 5 Prius Main Forum' started by Hipparchus, Mar 22, 2024.
  1. bwilson4web
    16,535
    A larger than 1 kW inverter will have more ability to deal with startup loads. But the sustained, steady state capacity of my 2003 and 2010 Prius were only:
    • 1 kW ~= 75 A * 13.5 V - steady state
    Higher currents would drag the voltage down keeping the power output at 1 kW. Below 12.85 V would start discharging the 12 V battery .... not a good thing.
    ps. I no longer have Prius and just recently had an inverter returned.
    Prodigyplace likes this.
  2. fuzzy1
    10,707
    I believe that recommendation was for aftermarket inverters powered from the 12V system. But I understand the OEM 120V-outlet inverters in the Primes (Prius and RAV4) run from the traction battery, not the 12V, so are not constrained to the same limits.
  3. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Yes, the PHEV's outlet comes from the vehicle charger assembly, so the inverter inside that assembly is drawing from the traction battery.
    The Japanese HEV's outlet I don't know - it has a standalone inverter, but I've not found the circuit diagram to tell whether it connects to the high or low voltage system. But it is specced at the same 1500W.
  4. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    The 120v outlet on my 2024 Prime SE is pretty robust - I just finished washing the car with a 13 amp Pressure Washer plugged into it. No problem with multiple starts and very convenient!
