153,000 Dead battery, 2012 Cii
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Serif, Jan 13, 2017.
  1. Serif
    Serif New Member
    25
    Providence Forge, Va
    My friend in insurance told me and cases like these "it would have been better if I had been T-boned this morning than have a battery like that go out".
    That seriously stunned me. I'm still not sure off he was bs'ing me.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I believe the order should be:
    1. positive of Prius then
    2. positive of the jump vehicle
    3. Negative or ground of jump vehicle
    4. Negative or ground of Prius
    5. Remove in the reverse order of the above
    might want to check the owners manual for other steps, but I believe there is a step for putting the car into "accessory mode" before you then put it into "on" mode to try and get the car to display "ready". It also provides guidance on when to disconnect the jump vehicle (pretty sure it is after the engine starts).
    Hope this helps.
    Keep us posted(y)
    WilDavis, AQUA-K and Mendel Leisk like this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    For those playing along in the home game:
    The correct number of times to jump your Prius 12 volt battery before replacing it, is One.
    The correct number of times to jump another car with a Prius is Zero.
    The cost in Money and Time of limping along with a bad battery is huge.
  4. Mendel Leisk
    42,309
    That's pretty the opposite of the connection sequence I'm familiar with, which is:
    Ok vehicle positive
    Dead vehicle positive
    Ok vehicle negative (neg. post)
    Dead vehicle ground (bare metal)
    Disconnect in opposite order.
    I'm not sure of the ramifications, if any, of doing it in your order.
  5. bisco
    52,807
    the problem with t boning is, you'd have to have insurance for being upside down. (which you may have) but what i see is, you're putting serious miles on your car, and need to account for maintenance in your business plan.
  6. Mendel Leisk
    42,309
    Ray got it righter. From the 3rd gen manual:
    Maybe I'll print that out, attach to underside of hood.
    #26 Mendel Leisk, Jan 13, 2017
    AQUA-K, Bluegrassman and Raytheeagle like this.
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Read it once 7 years ago. Not too bad for a young guy;).
    I keep the manual in the car along with the jump pack. That way the one time I need it, I have everything I need at my disposal :).
  8. Mendel Leisk
    42,309
    On 4x6 photo paper. Have some sticky backing adhesive. :)
    I've attached a jpeg, set up for 4x6 printing, not "borderless", at 100%
    AQUA-K and Raytheeagle like this.
  9. bisco
    52,807
    have we solved the o/p's problem?:p
  10. Mendel Leisk
    42,309
    I know, I know. :oops:
  11. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    This only works if you use the underhood jump point and it is placed under the hood .
    Op used the physical battery under the seat.
    Good suggestion though(y).
  12. Serif
    Serif New Member
    25
    Great, I had it exactly backwards.
    I do not think I had a place in the driver side fuse box to clamp too.
    I looked it up and it sure looked different.
    By the way, what does op or o/p mean?
    Raytheeagle likes this.
  13. bisco
    52,807
    original post or poster.
  14. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I have a 2010 Prius II so below is what it's fuse box looks like:
    I had a charger on our Prius recently and here is how I use the clamps for positive and grounding, useful for a jump pack with short cords:
    Check your fuse box out and I think you'll find something similar.
    OP means Original Post or Original Poster. Shorthand saves some typing ;).
    Keep us posted (y)
  15. Serif
    Serif New Member
    25
    Yes I drive 110+ any given work day. Which is averaging 6 days a week.
    Only down time is holidays.
    Yes I was unaware that the battery would go before I paid the car off. Along with the cost of a HV battery.
    Live and learn.
  16. bisco
    52,807
    still, even if it is the battery, you can do much better than 5k. and the rest of the car is just broken in.
    the batteries themselves are around 2k, and you can find someone to install for a few hundred. or better yet, hopefully toyota will help.
  17. Serif
    Serif New Member
    25
    This what I was looking at.
  18. Serif
    Serif New Member
    25
    I was looking at the driver side box.
  19. Serif
    Serif New Member
    25
    I really hope so. I'm dreading getting stuck with a hefty bill. I need great gas efficiency to make my job and distance work for me and my family.
  20. Serif
    Serif New Member
    25
    Thanks again for your support. I will keep you all posted. And answer and questions you have.
    Mendel Leisk and bisco like this.
