153,000 Dead battery, 2012 Cii
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Serif, Jan 13, 2017.
  1. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    When the fusible link blows isn't the most likely victim going to be the inverter, not the traction battery?
    Raytheeagle likes this.
  2. Mendel Leisk
    42,389
    Is it for sure the hybrid battery, or could still just be blown fuse, due maybe to jump start? (n)
  3. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    ^^^^ THIS x10!!!
    m.wynn likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Found this online:
    Not sure what happened to your red positive cover, but it should be there.
    Keep us posted(y).
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I would tend to recommend Liftback for that many miles/day, but I was not expecting a longevity issue with c.
  6. Mendel Leisk
    42,389
    Early c's didn't have jump point under hood. Owners need to jump or charge directly at the battery, under rear seat. Apparently not that easy either.
    XRinger and Raytheeagle like this.
  7. Serif
    Serif New Member
    25
    Providence Forge, Va
    Yes , I had to go under the rear passenger seat.
  8. Serif
    Serif New Member
    25
    I did look I that fuse box first. And was stumped when I didn't have that jump spot.
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Thanks for clarifying @Mendel Leisk . Wonder how that one slipped through the cracks at model release time:confused:.
    Definitely looks difficult and there is enough combustible materials around that if a spark were to fly during the connection process, it might make life a little more exciting :(.
    Also makes checking the 12v battery health more challenging.
  10. Mendel Leisk
    42,389
    I ended up affixing it to the fuse box lid, thinking:
    1. It's primarily for me.
    2. Anyone else doing a jump start would as likely as not pop the hood, start looking for a battery.
    Apologies for the ongoing thread hijack btw.
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Definitely a good idea at a common point of use. Saves the hunt and peck through the owners manual when you are wanting to get going.
  12. Mendel Leisk
    42,389
    I think (at least) one really important thing is to never:
    Connect both ends of either battery first, then be wandering around with the two clamps at the other end: touch them together and BAM!
    A lot of rules get dictated, and not enough the reasoning, logic. Story of my life, lol.
    WilDavis and Raytheeagle like this.
  13. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Thanks to this site though, we get to see a lot of reasoning from the experienced folks:). That way us young bucks don't have to let history repeat itself;).
    Keep the stories flowing as opportunities present themselves. I for one listen (y).
    Bluegrassman and Mendel Leisk like this.
  14. Serif
    Serif New Member
    25
    $137 Diag
    $17 Fusable Link
    A ton of fuses replaced.
    Car now runs.
    No radio.
    No windows.
    No lights.
    They say that they now can do the rest of the Diag to trouble shoot the other issue.
    They are saying reversed polarity caused the link and fuses to blow.
    But the car is exactly the way I towed it to them, other than it's running.
    I had to give them the green light to run an additional Diag.
    Raytheeagle and Mendel Leisk like this.
  15. bisco
    52,927
    sounds right. sometimes, things are more extensive than we would like them to be.
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Replacing the 12v battery while you are at it:)?
  17. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    ...yup! (...see what George Santayana had to say about that!!)
  18. Serif
    Serif New Member
    25
  19. bisco
    52,927
    what was it, fuses? what would cause them to blow?(n)
  20. Serif
    Serif New Member
    25
    I do not know what the root cause was. But after two diagnostics and done fuses, the car works fine.
    The battery tested good. Everything is now testing fine. I'm going to be a bit skeptical for a while.
    Thanks for all your support. Just glad it's not a 3k bill.
