15amp to 10amp wall plug
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by HydeLiYoung, Aug 24, 2022.
  1. HydeLiYoung
    HydeLiYoung New Member
    New Zealand
    I'm in New Zealand.
    I was supplied a home plug but to my suprise I find the earth pin is a lot thicker than a regular pin.
    I found out that this is a 15amp plug but all my home outlets are 10amp.
    Has anyone used a 15amp to 10amp conversion/adaptor?
  2. LeviSmith
    LeviSmith Member
    108
    38
    NY
    You don't want to plug something that needs 15 amps into a plug that can only supply 10 amps. That's asking for a fire. It sounds like you either need to upgrade your outlet to 15 amps or get a different EVSE(the cord that plugs into your car) that won't draw more than 10 amps.
    49,399
    welcome!
    is new zealand 120 or 240 volts?
    if 240, 10 amp may be enough, but i would check the manual. you probably need an electrician.
    you can't convert 15 to 10 amp, but there are adapters for the correct applications
  4. nicoj36
    nicoj36 Active Member
    495
    158
    Is it only 15amp? Because usually it allows a lower amp and the highest amp. Mine can do both 7.5amp or 15amp, depending on my outlet’s output.
    Double check your charger and see what its exact inputs. You can look up the brand, model, or serial number and see the exact specs.
  5. bisco
    49,399
    the prime has that option, but the pip didn't
  6. fuzzy1
    10,166
    I'm not finding an Owners Manual for your country.
    But according to Toyota New Zealand, you need a real 15 Amp circuit. Period.
    Unless your Owners Manual shows a way to reduce the charging current to under 10 amps, then you are stuck with needing to upgrade your home by installing a 15 amp circuit from the circuit breaker panel.
    Toyota Used Prius Plug-in Hybrid - Toyota NZ
    "Do I need a special charger?
    No, you can simply plug the Prius straight into a 15Amp New Zealand electrical outlet. Talk to your dealer about charging requirements for your home. "
  7. RobPHV
    RobPHV New Member
    Melbourne
    My understanding is the ZVW35 has a 2kW onboard charger when on 240V, so 9 amps.
    I use a hardware store (Bunnings Australia) 10A wall to 15A socket converter with RCD and over-current protection.
    I originally got the adapter for my inverter welder but it works fine with the Prius.
